A constant buzzing zeeing in my ear I cannot sleep I am up 24 hours 7 days
    Brigadier General:
  • 3,400 Answers
SE A DOCTOR.
Posted on Dec 31, 2013
Why do young child struggle in daily routines?
There are many reasons a young child may struggle with day to day routines. The most common reason is their attention span. Up to the age of 5 years old, a child usually has one minute of attention span per age, so a 2 year old has a two minute attention span, a 4 year old has a 4 minute attention span, and so on and so forth.
The second most common reason is that they are given too much responsibility too soon. While children can help with chores at all ages, the chores need to be age appropriate, so you might give a 2 year old a dust rag to wipe a table with but you wouldn't give them a vacuum cleaner of course.
Another common reason is that children don't get nearly enough sound sleep these days. Infants and toddlers need on average 12-14 hours of sleep a night. Some may be able to get away with as few as 10 hours, and others may need as many as 16 hours of sleep a night. 3-5 year old's need anywhere from 10-13 hours of sleep a night and some need as many as 14 hours of sleep a night, while others can survive on only 9 hours of sleep a night. Older children in the 6-13 range need a minimum of 9 hours a sleep a night, and the average child in that range needs 10-11 hours of sleep. Some get by on as few as 7 hours while others need as many as 12 hours. No child under the age of 13 should be sleeping less than 9 hours a night. If they are, it could be one of the reasons that you struggle with the day to day routine, especially if it's the morning routine.
Other common reasons for a child having a hard time with a day to day routine is the need for a nap, not drinking enough water, too long of a wait between meals or snacks that's causing low blood pressure, and distractions by siblings, video games, etc.
Jan 04, 2017 | Preschool
Can the inverter split system heat pump produce low level frequency noise in a concrete building
No...
Barbara Keevan (hello),
Pressure in your ears...Please... read this all... to the bottom.
(unless there is a full time transformer in it... then ABSOLUTELY).
Not even my nasty old solar inverters make noise 24/7...
Look for a mongo-sized transformer that is ON all day...
even a MUNDANE old fluorescent light in a garage area...
Transformers are everywhere... aaand...
they can be quite obnoxious!!
Happy hunting...
Please comment me back if you doubt my sincerity!
Oh by the way... Headaches & sensitivity to noise... ear fullness.
Have your ENT (ear-nose-throat DOCTOR) Specialist
run an ANCA ("P" or "C") titer test...
(ANCA = anti-neutrophilic cytoplasmic antibodies) ...
EAR PRESSURE ...
1st symptom of WEGENER'S Granulomatosis, MPO, (et al).
Alternate Medical Specialty (avenue): Rheumatology.
((see links below))
You might be experiencing EARLY symptoms of an rare auto-immune problem...
When left to "PRESENT" it (they) can be quite catastrophic & can destroy lungs ... kidneys... etc. (I rather scare & not miss such an important opportunity).
Seriously (pay attention to your body)...
and remember: for every Doctor that graduated at the TOP of their CLASS... there was another on the very BOTTOM...
And again: Good luck with your hunt.
(may the second one be a complete waste of your time).
http://www.thedoctorsdoctor.com/diseases/anca.htm
Anti neutrophil cytoplasmic antibody
May 02, 2016 | Daikin FTXG12HVJU/RXG12HVJU 12000 BTU 24.2...
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Need instruction for setting time of day
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Paragon 1015-00RS Indoor Multi Operation...
Is there any way I can take off the sleep mode on the nokia 6700 slide? As it just looks like a blank screen and to check for messages or missd calls, I need to press a button Thanks
A quick answer is NO you can not disable the blank screen, it's set like that for a reason. The back light of the display uses lots of power and the battery would be discharged in 3-4 hours if left on. Also the display isn't designed to work 24/7 and if it did would self destruct anywhere between 45 and 90 days of constant operation.
Jan 26, 2011 | Nokia 6700 Slide Cell Phone
My salt water pump constantly stays on code 93. Does that mean that the pump is not working?
93 is sleep mode
after setting the # of hours you want the pump to run and it runs those hours it then goes to sleep mode
If you do nothing the unit will come on again in 24 hours and then run the same amount of hours as previously set
If you want to change the hours then un plug and re plug in
Every day could be different some days you may need 4 hours or so and others upwards of 12
Aug 04, 2010 | Intex Automatic Salt Water System for ...
I am watching lcd tv 32" continuously for 7 hours per day, is it ok?
Yes that is NOT excessive some clients have the units on 24/7 literally... It is more the turning On & OFF,that causes problems, you see, it is the "Inrush" current that damages things. So, so as long as a unit doesn't overheat, the less it is turned On & Off the better for the unit. Which is why these days many units have a "Sleep" function.
Mar 03, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
My printer can't and read the USB cable.
If this is a HP LaserJet P2015dn Printer try the 24 hour # listed below.
I've spent countless hours trying to install new hardware by going on line but I eventually solve the problem when I break down and call the 24 HOUR NUMBER!
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products
Be prepared to provide the following information: Serial Number (S/N), product name, model number
HP TouchSmart PC products
866-408-5408
24 hours a day, 7 days a week. U.S.: English and Spanish.
Compaq Presario PC products 800-OK Compaq
or
800-652-6672 24 hours a day, 7 days a week U.S.: English and Spanish. Customers using TTY 877-656-7058 6:00 a.m. - 3:00 p.m. PT
Mon. – Fri.
excluding holidays
Jan 20, 2009 | HP LaserJet P2015dn Printer
My hp 2015dn printer will not print.
If this is an HP Printer try the 24 hour # listed below.
800-HP invent
or
866-408-5408
or
Mon. – Fri.
excluding holidays
Jan 18, 2009 | HP LaserJet P2015dn Printer
P2015DN Left side of image cut off
I've spent countless hours trying to install solve printer problems by going on line but I eventually solve the problem when I break down and call the 24 HOUR NUMBER!
800-HP invent
or
866-408-5408
or
Mon. – Fri.
excluding holidays
Dec 15, 2008 | HP LaserJet P2015dn Printer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
