Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
I bought a NAD Digital Phono/USB Preamp PP3 from www.nad elecronics.com. Mainly to record from Vinyl Records to CD/Computer. I connected on the device the white and red plugs in MC, the sound is working, the turntable is turning, but no sound... Thanks in advance for your assistence.
  • henk2 May 20, 2009
    I doubt it's the wires (though I am a layman in this field). Because the system worked some years ago. Can it really be a solution to plug the white plug in the red hole? Is there another vision on this problem? Thank you
  • 355 Answers
The output level of a phono cartridge will
vary greatly depending upon the cartridge's
design. It can vary from less than 0.2 millivolt
for low output moving coil cartridges to 5 millivolts
or more for moving magnet cartridges.
Lower outputs are often associated with
better cartridges where the designer has
used smaller coils and/or magnets to lower
the moving mass of the stylus/cantilever
assembly and, thus, improve the sound.
As a guess, the "5.0" in the model
designation of your old cartridge suggests it
had an output of 5 millivolts.
The new Grado has a lower output,
thus requiring you to turn up your volume
control to achieve a similar
output to your old cartridge.
This is not a problem unless you
cannot get sufficient volume or
if you get to much noise when
turning the volume
up to your preferred levels.
If that's the case, you will need to get new
electronics to handle the lower output
of the Grado.
Posted on May 20, 2009
  • Rohit  Asthana
    Rohit Asthana May 20, 2009
    check this pdf..
    here you will find step to step
    http://www.andbenelux.com/component/opti...
  • Rohit  Asthana
    http://74.125.153.132/search?q=cache:kkk...
    Novelist:
  • 151 Answers
Its the setting problem.the wires are not getting proper connection.remove the wires and interchage the wires to connect then to differecnt ports.connnect red to white and white to red.or get the set of new high density wires for this  as if the wires which you have low density thickness it does not provide required volt to the unit to produce sound. you will get the required wires at  www.radioshack.com or at  www.bestbuy.com
thanks. please keep updated.thank you for using fixya.
Is an unidentified player compatible with an NAD integrated amp which has analog inputs?
As long as the "player" has phono connections you should have no problems with compatibility.
Jan 23, 2016 | NAD Audio Players & Recorders
How do i record vinyl onto cd using rcd-w100
PLAY the record on a turntable that either HAS a PHONO preamp or through a PHONO preamp.
Sep 12, 2011 | Sony RCD-W500C 5-Disc CD Recorder
When recording vinyl to cd ..when i play the cd back i can hear the cd motor on the recording
Hmm, no products identified nor connections defined.
It is more likely you're recording the turntable motor than the CD motor. Are you passing the vinyl through a PHONO preamp as required?
Sep 01, 2011 | Audio Players & Recorders
I have a NAD turntable. I have noticed that on occasions there seems to be a background crackle.. Thought it was dust at first !! Have swapped the connection over where the turntable plugs into the amp....
Either you have a poor earth connection or you are getting a lot of static from the records you play. The best way of getting rid of static is a spray you can get for cleaning records. Search on-line for Anti-Static Record Cleaner.
Jun 15, 2011 | NAD 533 Turntable
How do I connect a Mirage Omni s-10 Sub Woofer and a Parasound Model 2100 Pre Amp to the NAD C372 Amplifier?
You DO realize the preamp is duplicating stuff in the Nad C372, right? This Preamps adds nothing but PHONO connectivity and control. That's why they're called "preamps".
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-C372-Amps-manual/id/8043dj592/t/2/
http://www.retrevo.com/support/Mirage-OMNI-S10-Subwoofers-manual/id/14438ag918/t/2/
Model 2100 Picture and article:
Use the Sub Out pair on the Preamp (joined by an RCA Y-cable) for the Sub Input on the sub (duh):
http://www.hometheaterhifi.com/preamplifiers/362-a-secrets-preamplifier-and-power-amplifier-review.html?showall=1
Run RCA from the Preamp Main Out to the C372 Aux In to hear any sources attached to the preamp.
Or, if you don't NEED the preamp because you don't have a turntable,ditch the preamp and connect the sub using the speaker outputs on the NADS, according to the manual.
Mar 08, 2011 | NAD C372 Amplifier
Where do I hook up the record player
That would depend on what type of outputs your record player has. If it only has RCA (white/black and red), simply choose one of the two RCA inputs. If it has optical or coaxial outputs, and you don't have another device you wish to use one of those, then those would be fine as well. Hope this helps!
Mar 01, 2011 | Yamaha HTR-5540 Receiver
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
Connecting NAD 2600a amp.
Never connect incompatible connections. Speaker outputs are for speaker inputs. Period.
The various inputs on this or most any amp are for Line Level signal with the exception of anything explicitly labeled "PHONO" as that would be for a non-preamplified turntable ONLY.
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used in the (assumed) preamplifier that fed this amp.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use the Lab In's UNLESS you have a turntable source.
Aug 22, 2009 | NAD Audio Players & Recorders
Play phono - vinyl records
You need to purchase a phono preamp (about $20) and then the output of the preamp can be connected to any line level input on the receiver (tape, CD, DVD etc.)
Dan
Feb 25, 2009 | Denon AVR-1602 Receiver
NAD T760
You should connect the RCA connectors from your turntable into the phono input of the preamp. Also, make sure you have the grounding wire from the TT connected to the grounding on the preamp (if you do not have a grounding point, then just connect it to one of the screws on the preamp). Then connect the output from the preamp to either the Tape or the CD points on the T760. On the front panel press tape monitor and you're done.
Check and let me know how it goes. My set up's working fine except for clarity, which still needs to be perfected. I'm using a normal step-up phono stage.
Regs/ Avinash
Mar 29, 2008 | NAD T760
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
69 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
