Question about MSI 760GMA-P34 FX Desktop Motherboard - Intel 760G Chipset - Socket AM3 Micro ATX - 16 GB DDR3 SDRAM Maximum RAM - Hybrid CrossFire Support - Serial ATA/600, Serial ATA/300 RAID Supported Controller - On-board Video Chipset - 1 x PCIe x16 Slot - 2 x USB
Bios is green, blue tint during boot
During every boot the color of the writing is light blue instead of white and the windows symbol coming on after that has a strong blue tint, you can hardly make out any of the colours of the windows symbol. As soon as it loads into Windows 7 all the colours are perfectly matched and balanced with no tint whatsoever. If I enter the Bios Setup while booting the bios has a strong lime green colour and doesn't appear to look right to me. The PC seems to be working fine apart from that, I have used it for video, browsing, music etc. and haven't had any issues. PC is brand new BTW. I have not been able to find any information on this or anyone with a similar problem. The Setup is FX 6300+ boxed cooler, MSI 760gma-p34 +onboard grafics, 4GB of Kingston HyperX 1600Mhz RAM, Kingston V300 120GB SSD, 530W Thermaltake German Series running Windows 7 Home Premium. Any ideas?
    New Friend:
Dont have sol
Posted on Dec 31, 2013
2 Suggested Answers
SOURCE: I have an msi ms-7390 k9n sli ver 2 motherboard
move the sata connection for your bootable HDD to another port like 3 or 4 and the bios will detect then run bios setup to boot from the sata 3 or 4 and it works like normal, must be a bug in sata 1 and 2. had same issue trying to install win7 x64. Win 7 refuses to detect sata DVD drive, moved it on the MB and it installed fine.
Posted on Apr 04, 2011
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Hi, During startup, I inserted a USB memory stick and now my screen is all messed up. It is green during startup instead of blue, and in general there are too many green pixels. (and purple pixels too) I...
remove the memory stick then try to boot up again, if still the same try to boot up under advance boot options, pressing "F8" repeatedly on the way up of boot up (from off to on) go to safe mode then try a system restore, see if that helps
Mar 23, 2011 | Medion Computers & Internet
Panasonic TC-P42U1 plasma. Lost it's vivid colors basic color is black and white and green and blue if tint color tone etc. Is turned up. However a blue ray video plays with full color. Could it be a lose...
I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
Jun 27, 2010 | Panasonic TC-P42U1 42 in. Plasma HDTV
Green screen
inside the light engine there is a red a green and a blue glass color filter.The heat from the lamp causes the color to burn off the glass.You need new filters .One is red one is blue and one is green.The lcd itself doesnt make the color,it is a black and white device.The colr comes from light shining through colored glass
Nov 11, 2009 | Hitachi 42V715 Rear Projection Television
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
MSI 760GMA-P34 FX Desktop Motherboard - Intel 760G Chipset - Socket AM3 Micro ATX - 16 GB DDR3 SDRAM Maximum RAM - Hybrid CrossFire Support - Serial ATA/600, Serial ATA/300 RAID Supported Controller - On-board Video Chipset - 1 x PCIe x16 Slot - 2 x USB  Logo
55 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
