Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Color alginment is off
I have tried to get the crosses algined to match a yellow color but some dont algin
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.color alginment is off - 0667c5f.png/>0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also loocolor alginment is off - 9e7eb5b.jpgge, dull, etc.
TV set after fluid change. Notice how bright the colocolor alginment is off - 182c282.jpg Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 22, 2009
  • 6,784 Answers
Hi. there is a circuit board that allows you to collaborate the RGB cross hairs and, this allows for sharp and proper streaming of the colors. this board is failing and you will need to replace the chip set(stk's) or, you can just replace the entire convergence board as well.
to confirm this, just unplug the unit for 5 minutes. after the five minute shutdown, plug the unit back into the wall socket or surge protector and, power it up. try to adjust the convergence once more. if you experience the alignment issue after the five minute shutdown, this will confirm my diagnosis.
If the convergence works after the shutdown, it will confirm that it was a minor hardware fault that was fixed by the five minute shutdown(hard reset).
Posted on May 20, 2009
We are trying to make cilantro caviar with the calcium lactate and sodium alginate and we cant seem to get it to se into the caviar. what are we doing wrong.
You're either pushing the plunger too hard or not hard enough. It has to drip even drops, not squirts or threads.
May 13, 2011 | Dishwashers
1515n manual
on this page
http://h10025.www1.hp.com/ewfrf/wc/product?product=3422468&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
select manuals and success!
Feb 22, 2011 | Office Equipment & Supplies
I have a 70' rear projection Hitatchi. the colors are no longer algined. how do i fix this
You will need to install the convergence repair kit for that chassis. www.tvrepairworld.com should have the repair kit you require.
Aug 27, 2010 | Hitachi Televison & Video
Epson C82
is ink in cartrigde then try with algin
Jun 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer does not work after refilling ink
  • algin cartriz
  • replace
  • is printer recognicing tha cartriz?
Jun 24, 2010 | Brother HL-2040 Laser Printer
My 2008 Mazda cx 7 keeps pulling to the right even immediately after a 4 wheel alignment. Could something else be causing this?
A problem that occurs is that people get a wheel alignment, bu the tyres have been wearing the same way, so they end up pulling to one side...this will get better over time BUT if you want an immediate fix, her's a tip, swap the two FRONT tyres over, and you will find that the car will run straight again....so it is a result of previous tyre wear that causes this, but shhhhhhh...dont tell anybody
vote for my answer if you like it
Jun 17, 2010 | 2008 Mazda Cx 7
Hp officejet k60 keeps saying press enter to algin cartridges
Check the controll panel and see if any key is presing down,if not open the control panel and clean the surface with metilated spirit.
Jul 05, 2009 | HP PSC 2210 All-In-One InkJet Printer
AUTO CONVERGENCE PROBLEM
you need the convergence power supply board. you can get one at the following link.
http://servicemanuals.vstore.ca/
Aug 06, 2008 | RCA R52WH73 Projection Television
Convergence
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
208 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
