Question about Husqvarna Sewing Machines
I have a Viking 64 30 that is 40 yrs. old. The cams will insert but I can't get the machine to respond to any stitches on the cam. The 3-step zig zag also will not work. Any hope? Thank you in adv
The machine does sew without a hitch. It just won't sew any specialty stitches. Someone said the inside part that the cams are inserted into is cracked. They also claimed that affected the zig zag problem. Any suggestions.
    Champion:
  • 241 Answers
Yes your fixed cam could be cracked and that will have those symptons. Here is a video.
Posted on Jan 30, 2014
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
SOURCE: zip zag troubleshooting for Ero Pro Shark Model 384
how to thead the euro-pro 373
Posted on Jul 11, 2009
WonderTech
  • 268 Answers
SOURCE: Whenever I zig zag my machine skips stitches.
Try these solutions.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure.
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
I hope this helps you.
Posted on Sep 15, 2009
Testimonial: "great advice!"
  • 6 Answers
SOURCE: viking 2000 owners manual
http://singerco.com/accessories/manuals.html (for your manual)
Posted on Feb 09, 2010
I have the settings correct but it still doesn't zig zag correctly??? what could be wrong???
try a new needle
could also be something wrong with the cam that does the zig zag stitch
would be a good idea to have the machine checked to see if there is something wrong with the cam
Mar 09, 2016 | Husqvarna Viking Emerald 116 Sewing...
How do you fix a left of center needle on a Morse Apollo 6500 sewing machine?
Is this machine new to you? Some of the older (but goodie) machines have a needle that defaults to the left. (I have an old Nelco that has this--great machine, just takes getting used to sewing with the needle in that position.)
Otherwise, I suspect the machine needs a thorough cleaning and oiling because the old oil may have dried out and is causing it to seize.
Jun 08, 2017 | Sewing Machines
Can't get the Husqvarna Viking Platinum 775 to do a zig zag
it's very possible that a cam or gear has worn down or broken
inside the machine and also if the sewing machine is computerized
then there could be a problem there, having the machine checked
would tell you for sure.
Nov 08, 2012 | Sewing Machines
I have a Viking 6370 sewing machine. I can not get the stitch selector to turn to select a new stitch. Actually the knob will turn but the outer dial doesnot turn and the stitch does not change. It sews...
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Jul 12, 2011 | Husqvarna Viking 1
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
I have a Viking sewing machine from the 70's. The cams aren't working correctly. I've had plastic parts and a metal ring replaced by a certified Viking repair person, but still not working correctly. ...
Was the inner zig zag gear replaced? To check this, look in the hole where the cams go. You should see the black plastic gear with 3 slots all the way around where the your cams lock on to. Look at the gear closely. You should NOT see any crack or splits in the plactic gear. If you do, then this why your go on properly.
Apr 25, 2011 | Husqvarna Viking 1
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
MAY NEED A CAM SHAFT FOR A FUTURA MODEL 900
I would get a second opinion about the timing...it has nothing to do with any cam.
Timing is relationship between Hook and needle, Cam is the stitch type.....if you can make a zig zag, timing is fine and all other stitches will be fine.....(provided tensions are balanced)
If cam is cracked, not all stitches will work, or may not be consistent, but the stitch will be created if the timing is good.
Handwheel tight...probably overtight motor belt adjustment....bobbin winding...well did it work before or is this new ?
Speak to Husky about a reputable service centre and have them take a look at it, they will also be able to advise parts availability if that proves necessary.
Aug 31, 2009 | Sewing Machines
Sewing Machines Logo
95 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
