Question about Kenmore 63673 1000 Watts Convection / Microwave Oven
Door will not open 1999 model
Door will not open and will not shut off
  • 1,511 Answers
The unit needs to be shut down by cutting power to the oven by either pulling the 110VAC plug from the receptacle or flipping the toggle on the house circuit breakers.
Posted on Apr 15, 2014
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
My micro wave door opens n does not shut tightly I guess and so takes about ten tries opening n shutting before it starts. What should I do Panasonic inverter microwave (the genius prestige) Model...
The door is either out of adjustment, the door switches are out of adjustment, or the door/hinges are damaged. If the door switch assembly can be adjusted to fix the problem, then make sure the door closes as snugly as possible. As any repair to a door can increase the amount of microwave leakage, which can cause possible health issues for you, it might be wise to, at the very least, have a technician do a radiation leakage test on the unit once the door problem is repaired.
May 08, 2014 | Microwave Ovens
Microwave making noise all the time if plugged in & door shut
Sounds like a bad control board. Change it or buy another unit.
Jan 21, 2013 | DeLonghi Microwave Ovens
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
My GE Spacemaker (HVM1540) will not turn off. Often when we use it and open the door to get food out, then we reclose the door and it continues to run. Even after hitting Clear/Off it continues to run...
Ok I have the same model and mine was doing the same thing. Apparently this model has a reputation of problems with the control board. I played with mine for hours and here's what finally worked: unplug the unit (or shut off the breaker--whichever's easier for you), take a dry cloth and wipe the door latches and control board clean of any residue. Then with the door still open, gently jiggle the control board by firmly grasping with your hand. Power up your unit again. This worked for me. The control board is really fussy and should be clean and free of any dust or residue. I notice this happens again when it gets dirty so I repeat the process and it's been working.....so far!!!
Jan 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
Display screen shows an F-6 and it quit working
F6 usually means that the cook relay is stuck on the control board.
So it probably is running whenever the door is closed. This can be dangerous, and can cause a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 18, 2009 | Microwave Ovens
Won't shut off
Chances are you have a shorted door switch, but all owners of a GE WES model might want to look at this blog post.
If it's been less than 30 days since you bought it, I'd hurry and take it back to the dealer for a refund, not an exchange.
Otherwise, GE Customer Service is here.
Oct 09, 2008 | Microwave Ovens
Bosch HMT9626GB / HMT9 / 0B 1000 Watts...
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Sep 15, 2008 | Bosch HMT9626GB Microwave Oven
Microwave door button spring broken and door wont open
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 05, 2008 | Microwave Ovens
Kenmore 63673 1000 Watts Convection / Microwave Oven Logo
35 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
