Question about Facebook Apps
Wipers not working - Facebook Apps
My front windshield wipers will only work on high. Any suggestions?
Search Results
    My windshield wipers only work on high speed...? ' Yahoo Answers
    https://answers.yahoo.com/question/index?qid...
    Nov 11, 2006 - My windshield wipers only work on high speed. ... If it's the compound switch on the lever on the steering wheel, it can be a bit complicated to ...
    Windshield wipers - CarGurus
    www.cargurus.com > Questions > Mercury > Grand Marquis
    CarGurusMay 19, 2015 - Windshield wipers - My wipers stopped last week and the next day they ... slow or intermitt and only work on high speed and the washer wiper doesn;twork ... The LCM does not effect the operation of the motor or switch it just ...
    Windshield Wipers only working at highest setting - Ford Flex Forum
    www.fordflex.net > ... > General Ford Flex Discussions
    Feb 16, 2011 - Windshield Wipers only working at highest setting ... rear wiper worksjust fine, just the front wipers only work at highest setting. ... the wipers sometimes grinds out the gears thus only working at high sppeds. If it is the motor or Transmission for the wipers, can I fix this myself and how much would it cost me.
    Common GM Wiper Problem - YouTube
    ? 3:23
    https://www.youtube.com/watch?v=kc6e2Tmar68
    Oct 25, 2010 - Uploaded by roadragecustoms
    The windshield wipers only worked occasionally. ... My 1998 dodge ram wipers only work on high will this help me? thanks.... Express van. you have to take out the motor and the transmission from under the front of the van..
Feb 09, 2016 | Cars & Trucks
Replacing wiper linkage
WINDSHIELD WIPERS
It can be faulty wiper motor or blown wiper control fuse.
Do you hear any kind of noise when you starter the wiper function. If yes then fuse is ok, but issue is wiper motor.
If no movement at all and no noise then its blown fuse or shorted/loose wiper control wiring: -----
For complete troubleshooting i suggest you few helpful links with accurate solutions.
Click the link below: -------
1993 Ford F350 wipers not working?
http://repairhelpcenter.blogspot.in/2012/02/1993-ford-f350-wipers-not-working.html
How to Replace a Windshield Wiper Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-windshield-wiper-motor.html
Wipers not working, but hear relay click on Lincoln LS?
http://schematicsdiagram.blogspot.com/2011/12/wipers-not-workingbut-hear-relay-click.html
Car windshield wiper gets power for movement and stops?
http://schematicsdiagram.blogspot.com/2011/12/car-windshield-wiper-gets-power-for.html
How does cars Windshield Wiper System Works
http://technoanswers.blogspot.com/2011/11/how-does-cars-windshield-wiper-system.html
1997 Honda Protege: Replace Wiper Transmission?
http://technoanswers.blogspot.in/2012/06/1997-honda-protege-replace-wiper.html
Windshield wiper fluid container leaking?
http://whatisbyme.blogspot.in/2012/05/windshield-wiper-fluid-container.html
Where is wiper fuse located on1993 chevrolet suburban
http://technoanswers.blogspot.in/2012/02/where-is-wiper-fuse-located-on1993.html
2002 Toyota Sienna: Wipers and Passenger side Power window stopped working?
http://technoanswers.blogspot.in/2012/04/2002-toyota-sienna-wipers-and-passenger.html
Complete wiper components replacing details for Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/complete-wiper-components-replacing.html
These details will help.
Thanks.
Nov 29, 2012 | 2003 Chevrolet Cavalier
Where is fuse for wiper fluid pump on a 2003 cavalier?
If no movement at all and no noise then its blown fuse or shorted/loose wiper control wiring:-----
Click the link below:-------
Thanks.
Nov 28, 2012 | 2001 Saturn S-Series
How to remove the windshield cowl on a 2002 tyota yaris
Complete wiper components replacing details ?
Thanks.
Nov 28, 2012 | Toyota Yaris Cars & Trucks
2002 intrigue wipers / washer dont work
Do you hear any kind of noise when you starter the wiper function.If yes then fuse is ok,but issue is wiper motor.
------------ How to Replace a Windshield Wiper Motor
Thanks.
Nov 27, 2012 | Oldsmobile Intrigue Cars & Trucks
Fix 2005 tahoerear wiper
For wiper problem,troubleshooting,check the help links provided below.Click the link to go through its procedure:----------------
HOW TO REPLACE A WINDSHIELD WIPER MOTOR
Wipers not working, but hear relay click? http://schematicsdiagram.blogspot.com/2011/12/wipers-not-workingbut-hear-relay-click.html--------- Car windshield wiper gets power for movement and stops?
Where is wiper fuse located?
Complete wiper components replacing details for Car Models? http://repairhelpcenter.blogspot.com/2011/11/complete-wiper-components-replacing.html The wipers not working? http://repairhelpcenter.blogspot.in/2012/02/1993-ford-f350-wipers-not-working.html
Mar 01, 2012 | 2003 GMC Yukon
Is there a procedure to check the wiper motor on 1991 S10 pickup (only 42000 miles), to be sure it is defective and not a wiring problem?
ONLY PROCEDURE FOR WIPER MOTOR IS YOU HAVE 2 SPEEDS THAT WORK SLOW AND FAST SPEED.WIPERS WILL RETRACT TO THE BOTTOM OF HOOD LINE WHEN YOU TURN OFF. WIPERS SHOULD TURN OFF. CHECK WIPER RESERVOIR MAKE SURE ITS FULL AND WIPER WASHER SPRAY FLUID CLEAN WINDSHIELD. IF WIPER MOTOR DO ALL THE ABOVE THEN ITS OKAY.IF WIPER MOTOR WORKS SLOW LOOK FOR BINDING AT WIPER ARM LINKAGE AND PIVOT LUBRICATE LINKAGE AND PIVOT COULD HELP.IF WIPER MOTOR DONT WORK CHECK FOR POOR GROUND OR BLOWED FUSE.WIPER WORK AT ONE SPEED CONTROL SWITCH IS BAD.IF WIPER BLADES STOP WHERE EVER THEY ARE OR FAIL TO TURN OFF UNLESS YOU TURN OFF IGNITION SWITCH WIPER MOTOR LIMIT SWITCH BROKEN.IF WIPERS DONT RETRACT BELOW BOTTOM HOOD LINE LOOK FOR MECHANICAL OBSTRUCTION OR WIPER MOTOR FAULTY.
Nov 14, 2010 | Chevrolet S 10 Cars & Trucks
Windshild wipers stop working
CHECK FUSE IF FUSE GOOD.HOOK A JUMPER WIRE TO GROUND AND GROUND WIPER MOTOR.TURN WIPER SWITCH ON IF WIPERS WORKS YOU HAVE TO FIX GROUND CONNECTION. IF WIPER STILL DONT WORK.REMOVE THE COWL COVER.TURN WIPER SWITCH ON TO SEE IF POWER GOING TO WIPER MOTOR IF YES.REMOVE WIPER MOTOR HOTWIRE IT.IF WIPER MOTOR DONT WORK REPLACE IT.IF WIPER MOTOR DO WORK CHECK FOR BINDING OR DAMAGE LINKAGES.IF POWER NOT GOING TO WIPER MOTOR AND FUSE GOOD.WIPER SWITCH FAULTY OR IT HAS BROKEN WIRE FROM SWITCH TO WIPER MOTOR.
Oct 04, 2010 | 2002 Toyota Avalon
Windshield wipers stopped working not fuse is there a relay and where is it
with the key on and the wiper switch in the low or high position tap the wiper motor with a screwdriver handle. If it starts working replace the wiper motor.
Sep 26, 2010 | 2002 Buick Rendezvous
Rear wiper does not work at all. front wipers work fine. rear washer works
1. check the fuse to the rear wiper motor
2. check for power to rear wiper motor at the motor (power wire going in to the wiper motor with rear wiper switch on)
If you have good fuses & have power going in to the rear wiper motor...
3. Pull old rear wiper motor and install a new rear wiper motor.
Thank you please drive thru......
Feb 26, 2009 | 2001 Ford Expedition
Facebook Apps Logo
629 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
