I can't find where to check the filter in hydronic furnace (Rinnai 37AHB)
I feel silly - but I can't find where I can check/change the air filter in our new hydronic furnace. The user manual is not at all user-friendly, and only says that it needs to be changed, not how. There is no obvious place on the furnace itself where this could be - all areas are screwed shut. Does anyone know where the filter is located, or do I really need to have someone come out and change it for me every 3 months?
  • Melissa
    Melissa Dec 31, 2013
    Nevermind - found it. If anyone else has this problem - there are 2 thumb screws on the furnace front. the filter sits on what looks like a coat hanger... (Side note - I miss my Trane furnace - much more user-friendly and the filter fit in more securely. This Rinnai furnace seems to be very cheaply made)
SOURCE: furnace filter on model gmt070-3a...
We had a similar question on our Goodman furnace, couldn't find where the filter goes.
Our furnace has two large metal covers that cover the lower and upper parts of the furnace in front, approximately 18 inches by 18 inches. The top one has a sticker that says "don't open equpiment, you may void the warranty". The filter is inside this compartment, at the bottom. You have to unscrew the screws that hold these two covers together, then just pull the filter out to change it.
I called the people who installed our furnace and aksed them if it really voids the warranty for us to open it up and they were non-comittal about it. Anyway, I opened it and changed the filter.
Posted on Jun 07, 2008
ginko
  • 19396 Answers
SOURCE: users manual for a rinnai 551f heater
Here is the owner manual : Rinnai wp
And here also an extra, the service repair manual:
Untitled
With compliments.
Posted on Nov 30, 2008
mrgrzz
  • 88 Answers
SOURCE: furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Posted on Jan 20, 2009
t1m130
  • 86 Answers
SOURCE: Heil Gas Furnace Filters
the filters will go by your blower compartment remove the doors at the furnace and look where the sheet metal opening meets the furnace
Posted on Jul 26, 2009
  • 80 Answers
SOURCE: How do you change the air filter on a Ruud silhouette II furnace?
If it is a down flow, it will usually be found in the return air plenum just above the blower. You need to remove the front panels and look inside above the blower. You may need to remove a second door to access the blower section. If it is an upflow, remove the bottom door and look alongside the blower where the return air comes in.
Posted on Oct 04, 2009
My rinnai energysaver 1001ft will not turn on.It has power to it but it will not power up when switched on.no lights no go.HELP;;
Hello Mark Obrien,
I searched the internet trying to get a HIT from your
rinnai+energysaver+1001ft
and all combinations there-of...
I also went on-line to a MAJOR RETAILER site & poured over their inventory of systems and parts (see below)...
Alpine Home Air Products Contractor grade furnaces heaters air...
Nothing... so:
Assuming you are talking about a heater here
If you are seeing no "lights"...
perhaps checking the SECONDARY side of your
POWER TRANSFORMER would be the best advice...
If that has the required (typically 24 volt output)
continue on to your main control board...
(looking for the Typical FUSE (usually 5 AMP)...
If the fuse is OPERATED... replace it...
f it operates again... IT is time to consider purchasing that
SPARE MAINBOARD you always wanted...
Like a YORK furnace... (verify your OWN NUMBERS)
031 01267 001A OEM Upgraded York Furnace Control Circuit Board by BDP... (PC (Main Control Board)
ALSO CHECK HERE
https://www.supply.com/rinnai-furnaces/b2098
Fuse kit
Amazon com Bussmann NO 44 ATC Blade Fuse Tester Puller Kit Home Improvement
Hope this helps...
Carnac the Magnificent
Jun 25, 2017 | Rinnai Heating & Cooling
Our red filter light is on and we have cleaned everything and now it makes 5 beeps every few minutes constantly
Check the air switch and tubing, if everything is clean, the switch is defective, the tubing is plugged or disconnected/broken.
Feb 10, 2015 | Rinnai Energy Saver Direct Vent Wall...
Rinnai 37AHB09016KA5 providing no heat
if this is a heat pump the switching valve could be malfunctioning. Check the for continuity on the valve.
Jan 03, 2014 | Rinnai 37AHB09016KA5 90,000 BTU, 3 to 5...
After being off all summer i click on but it wont fire up i checked for carbon the tank is full i have a rinnai 1004f
Do you get an error code? 11. 12 68, 72, etc. Does the combustion motor come on. You should be able to hear it. Is the exhaust and air pipe clear? Is the air hose hooked to the back of the stove?
Tom
Sep 17, 2010 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
I want to upgade from my old water tank to a tankless water system. I have underfloor heating and it has 4 zones but i run it as one zone and it is controlled from a therm ostat that controlls a pump.I...
what you have is called a hydronic heating system.
this heating system is completely isolated from your water heater I believe this as most hydronic systems I have installed circulate water through the furnace to heat the house. If this is true you need only to connect your old water heater cold water supply side to the tankless and, old hot water side to the house system: the showers/tubs/sinks etc. in your home.
my appologies if I have missunderstood your inquiry.
Jan 26, 2010 | Rinnai Digital Remote Water Heater Control...
I'd like information on the reliability of Rinnai 1004FA furnaces. Do they need regular cleanings?
Beside the filters in the back, no they don't require much. After 8 years of installing and servicing these units, I haven't found a unit yet that was running faulty due to lack of service. Would recommend a cleaning of the burners about every 3-5 years. Rinnai recommends cleaning the unit with compressed air through the front grate annually...but that doesn't require disassembly
Sep 11, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 431 wont start
You could have something as simple as a blocked flue pipe. Check outside and make sure the pipe is clear of ice or snow. Check the circulating fan and filter for lint. Be sure the lovers on the front of the stove are open and clean of lint.
Tom Hawkins
Apr 07, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai 431wt filter light won't go out
If you have changed the filter, and the light stays on then you need to let the system stay down for 24 hours without running. Also go ahead and check the vent cap on the outside of the unit. The light will go awaa by itself if you need to use the system
Feb 08, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
