Question about Apollo Half Time Convection - Microwave Oven
Half oven is working microwave oven is not working
Microwave is not heating food. Half oven is working. Turntable turns and fan and light come on. We are in a RV Fleetwood Pulse. Model # AACZ4OTRB
You can buy it from Sears for $52.00 or you can call 1-800-330-9707 and they will mail you one free.
Posted on Mar 02, 2014
Reset button on microwave?
Chances are you've blown the fuse under the outer shell.
There is no reset.
Feb 15, 2014 | Panasonic NN-SD688 Microwave Oven
Bravetti euro pro microwave convection oven stops working
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#7#ixzz2hPnOVle4
Oct 11, 2013 | Toaster Ovens
It wont turn on model T0131SWD!!!!!!!
follow this charter troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gUR97IFo
Oct 01, 2013 | Black & Decker Toaster Ovens
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
    in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
    Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
    Microwave will not heat.everything else is working.is there a fuse?
    There is a fuse, it is a high voltage fuse. If this has blown there is a problem in the high voltage circuits
    Feb 16, 2010 | Toaster Ovens
    Microwave goes on but does not heat
    • Magnetron is fried. Resistance between the magnetron terminals should be less than 3 ohms. Resistance from the magnetron terminal to ground should be infinite.
    • Fried HV capacitor. Use your ohm meter to test it.
    • Fried control board. If power is going to the board but not going off to the other components, the board is bad and needs to either be replaced or track down the bad connection (GE/Hotpoints).
    • HV Rectifier is shorted or open. Test forward and reverse bias with a megohmmeter. If continuity in both directions, rectifier is shorted, replace. If no continuity in either direction, rectifier is open, replace.
    • More help on testing specific components inside your microwave oven in this handy chart.
    Aug 14, 2009 | Oster 4877 / 4878 / 6209 Toaster Oven with...
    Oster microwave/grill
    ha, had the same problem, just call the oster custumer service and they can send you a new one for $5
    1-800-968-9853
    Oct 06, 2007 | Oster 4877 / 4878 / 6209 Toaster Oven with...
    Oster microwave with convection/grill
    I just had the exact same problem above...
    I purchased the microwave from target about 5 mos. ago payed near 200 for it..half of the time the couldnt get funtions to work well,then had heating problems until last week it nearly almost burned my kitchen up..good thing I was here.I just spent one hour at target,and of course no help..reffered me to a number,but I already know where that s going to go! Im not blaming target,but when there is a defect in the product and you can clearly see and smell that it is burnt up then, they should or the manuf. should simply replace it.It wouldnt have mattered if I had the dang receipt anyway,after 90 days in target,your screwed!
    I like walmart much better,and I guess I have to go and pay another 125.00 or something for a much less complicated one.
    thanks for the info above Laura florida
    May 28, 2007 | Oster 4877 / 4878 / 6209 Toaster Oven with...
    Apollo Half Time Convection - Microwave Oven Logo
    216 people viewed this question
    Top Apollo Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you an Apollo Toaster Oven Expert? Answer questions, earn points and help others
