Question about Lite On Computers & Internet
Lite On DVD recorder 5005 tray will not open - Lite On Computers & Internet
See if it has a pinhole somewhere near the eject button on the actual drive. Use a safety pin to try to EJECT it.
Posted on May 01, 2014
Invalid disc error
Most likely you need to replace the drive, they are very cheap on ebay. Here is how to replace it 1st power up and open tray then unplug. remove front of tray, it unclips at bottom, pull out and up then slides off. remove screws and take the entire drive out. Remove base plate of replacement drive and screw down into the two rear mountings. Remove facia of Recorder and cut out the three little pieces of moulding directly above where the tray drawer will be, this prevents the drive from being forced down at the front. With facia off fit the drive back onto the now screwed down base plate. Replace facia, connect drive power up and open drawer then unplug. On the drawer front cut off the centre small moulding because it doesn't line up with the cut outs in the drawer, the other two do, slide the front downwards onto the drawer then press at the bottom till it clips in. Job done. My 5005 now reads much faster and recognises all discs prior to this Invalid Disc on everything, cleaned lens and it would then only see pre-recorded films etc but no blank discs.
Mar 06, 2011 | Lite On LVW-5005 DVD Recorder
I need a replacement control for lite-on rite dvd recorder 5005
http://stores.ebay.co.uk/GenuineCopies_LiteOn_W0QQcolZ4QQdirZ1QQfsubZ7243871QQftidZ2QQtZkm
you will find the original remotes here
hope this hepls
and please will you rate us, regards
Nov 28, 2008 | Lite On LVW-5005 DVD Recorder
Dvd recorder repair
Remove the cover of LVW and access the dvd assy,unscrew the 4 screws holding the dvd assy to the LVW bottom.
Remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).
You will access the dvd spindle.
Remove the dvd stuck inside.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
LVW-5005
Unplugging the power chord to unit for sometime (around 20 - 30 minutes) and plug back the power chord .
After that press the eject button for 30 seconds at times this may work and you can get back the dvd from the player .
The tray won't open. There is a disk in the tray and I was able to play it back. But, when I tried to eject the disk, the tray woudn't open.
something like this is a physical problem. you should contact the manufacturer to see if there is a manual eject button and if not you will have to take it apart to get the disk.
Tray will not open
hi had the same problem, unscrew the top off from panel and just like a computer burner there is a button on the front of the burner on the inside independent of the eject button, that is away from the actual eject button. my friend drilled a small hole on the front near the burner from the outside and i stick an allen key through they hole and the tray will come open, not sure why the eject buttons are dodgy, but this should work. and do u know where i can get a replacement remote or which universal contol will work?
Oct 21, 2008 | Lite On LVW-5005 DVD Recorder
Lite-on DDW-813s
Open the drive (dont break it). Eject the tray, under the tray you should see a small belt drive. Replace the belt with a rubberband of approximatly the same size (a little smaller wont hurt). Re-assemble the drive and it should eject fine. Lite-On drives seem to go through these belts pretty quick, I have fixed hundreds this way. Never had one I fixed come back for the same problem.
Feb 16, 2008 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5005 DVD Recorder video is not working
try installing more codecs to your computer. search for mega codec pack.
Sep 01, 2007 | Lite On LVW-5005 DVD Recorder
Computers & Internet Logo
42 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
