Question about HP LC3040N 30 in. HD-Ready LCD Television
Change picture size without remote - HP LC3040N 30 in. HD-Ready LCD Television
Change the picture size without the original remote
To select the aspect ratio of picture, you should have its remote cotrol.
Dec 22, 2013 | Sharp 32L-S400 32" TV
Somehow our picture became HUGE! So huge the picture doesn't fit the screen. I can't find the remote. I there a way to minimize the size of the picture without the remote?
It will be very difficult to explain how to do it without a remote so, instesd, buy a universal remote control available at drug stores, etc. Then you can go into the TV menu and setup and define the picture size.
Dec 31, 2012 | Televison & Video
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
Zoom adjust on RCA D52W19 tv WITHOUT remote
if you have the original remote, your right and left arrow keys adjust the size, if size changes during commercials, get into your options and turn off the auto-size option, if you don't have the original remote, you must find a universal with proper mright and left arrow buttons.
Sep 15, 2009 | RCA D52W19 52" Rear Projection Television
Wide screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
The name of the button on the remote is called format.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 18, 2008 | RCA F27650 27" TV
The picture is too big for my screen
press zoom on the remote control to get the normal size
Dec 24, 2007 | Toshiba 35A44 35" TV
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
HP LC3040N 30 in. HD-Ready LCD Television Logo
20 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
