Question about Belkin (F5D7231-4) Wireless Router
CAN`T FIND NETWORK KEY, i tried 192.168.0.1 could not connect
I have a belkin wireless router cant remember network key
Try 192.168.2.1
Posted on May 26, 2009
    President:
  • 1,383 Answers
Belkin router are always http://192.168.15.1
aslo try 192.168.1.1
Posted on May 20, 2009
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Wanna know how to secure my belkin wireless G router.
Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed
Configure Wireless Security on Belkin Router - Enable WPA and WEP Why should we setup wireless Security on Belkin Wireless Router ?
After configuring your Belkin router you should secure your wireless network using proper wireless encryption. It can keep wireless hackers away from your wireless network and the unwanted sharing of your Internet connection. In order to know how to login and configure your Belkin wireless router click on the link below.
How to Setup Belkin Wireless Router
Setup Wireless Security in Belkin Wireless Router
Now I hope you just followed the steps mentioned in the above link and log in to your Belkin Wireless Router. In order to enable wireless security on your Belkin router click on Security Under wireless. ( Security tab present on the left side of Belkin configuration page).
You can select either WEP or WPA to secure your Belkin Wireless network. To know more about WPA and WEP click on the link below.
Which is better WEP or WPA on your Wireless network
Enable WEP in Belkin Wireless Router
To select WEP for your Belkin wireless network ,click on security mode drop menu and select WEP. WEP is of two kinds WEP 64 bit encryption and WEP 128 bit wireless encryption. You can type your PassPhrase and generate instant wireless key for your Belkin wireless network.
After generating the wireless key, you should save settings by click on Apply changes. Now onwards to login to your Belkin wireless network, you need this wireless key.
Enable WPA in Belkin Wireless Router
WPA is more secure than WEP. To enable WPA on your Belkin router, select WPA from security mode drop down menu.
You should enter a pre-shared key to enable WPA security on your Router. Don't forget to save this WPA settings.
Aug 28, 2011 | Computers & Internet
The belkin rounter of my dad's laptop was installed without password setting. i tried to set it up on 192.168.2.1 configuration page. i was notified that the rounter will restart again itself...thereafter...
If you can still remember the password that you entered on the configuration page, follow the steps below:
1. In the lower right corner of your screen (near the time and date), right click on the wireless network connection icon, then select view available wireless networks. Or, if your wireless adapter has its own wireless utility, you should see that in the lower right corner of your screen.
2. You should see the router's wireless network name (SSID). By default, the SSID is "belkin54g". Select the SSID and it will prompt you for the network key.
3. The network key is the password that you entered on the router configuration page.
If you cannot remember the password that you entered, follow the steps below.
a. Connect your computer to the router using an ethernet cable.
b. Access the setup page by typing 192.168.2.1 in the address bar.
c. Go to Wireless -> Security. Copy the network key.
d. Then follow steps 1-4 above.
For the MAC computer:
1. From the Airport menu, select the SSID.
4. When asked for a password, enter the network key that you entered on the router.
I hope this helps!
Jun 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cant remember my network key for my Belkin Wireless router. just got a new laptop and am trying to set it up. if necessary i will reset it!
First connect your router to computer with ethernet cabled.
Then you can access it with default ip
http://192.168.15.1
then type user as "admin" and password as "admin" or blank "password"
Then go to wireless secirity.
thjnen add new WEP code key it is your new password to connect.
But if you are not able to access router configuration page then you have to reset it.
for that press RESET button it in backl panel of router press it for 10 seconds.
Let me know if you need further assistamce.
Thanks.
Nov 06, 2009 | Belkin (F5D7230-4) Router (587009)
Cant rember password
Your wireless router is prompting you for a password in order to log onto your network. If you do not remember your password, you can reset the routers' configuration by holding down the reset button on the back of the router, and you can then use the default user name and password to change the settings. HOWEVER, you will lose all of your network settings so if you have multiple devices connected via wireless,they will also have to be reset.
If you need help re-configuring your router, visit the router manufacturer's web page. There should be a tutorial to walk you through the process.
If you happen to have a Linksys wireless router, here is their page: http://www.wikihow.com/Reset-a-Linksys-Router
Sep 06, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Trying to connect new laptop to wireless network cant remember password help
An easy way to get the password for your wireless network is to connect your laptop directly to the unit via ethernet cable. After you get an ip address connect to the router. If you dont know how to do this you can usually go to manufacturers website and it will tell you how to login to the router. Once you are logged into the router you can go to the Wireless Settings page and see what key you are using and what type of encryption you are using.
Jul 30, 2009 | Belkin (F5D8231-4) Wireless Router...
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Wlan light orange
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
Apr 25, 2009 | Computers & Internet
How to get password key
WEP password is on botom or on the side of the router
Dec 13, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D7231-4) Wireless Router Logo
428 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
