Question about Vizio VHT510 Theater System
Vizio vht510 Sound bar will not go into pairing mode. LED stays lit orange/blue. I have reset and power cycled.
  • 59 Answers
SOURCE: Vizio tv orange light on, not blue, won't bring up picture
if orange it is on stand by mode ,the cable that you changed is it power cable if yes then you used wrong one it may affect, i think you need to check power supply board . also get other opinion too. good luck
Posted on Apr 29, 2010
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
SOURCE: CANT GET SOUND FROM SOUND
I had a similar problem. I tried all the TV settings, but still it would not work. I plugged the sound bar directly into the cable box (AT
Posted on Oct 18, 2010
Ironfist109
  • 3018 Answers
SOURCE: VIZIO VHT510. soundbar and subwoofer work. No
Do you have them connected to the sub? Those satellite speakers pick up the fainter sounds and work best in movies with 5.1 surround sound. Make sure they are behind the primary listening position. And try them with a 5.1 surround movie. If all speakers are up front switch to front listen mode. Good luck.
Posted on Mar 06, 2011
  • 4 Answers
SOURCE: Hey I'm trying to program my Comcast remote to
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)
Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:
Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Posted on Nov 18, 2011
How to test Tcon and other board on Vizio television. When I first connect power logo is bright orange, then slowly dims.
That isn't a timing control board issue, see if you have PSON voltage for starters, if you do then test the various power supply voltages, it could be either the main or power board giving issues, but I would bet on the power supply is bad since the logo comes stays on
Jan 31, 2018 | Vizio Televison & Video
I own a Vizio VF550M and all I'm getting is the "Vizio" logo is lit orange and won't turn on, nothing. I ordered in a new power supply, put it in, and still the same results. What could be causing th
A corrupted firmware can cause this. Just do a hard reset to this TV, and check. If it do not help you, contact the authorized service centre for Vizio. The firmware to Vizio is not available by internet.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 09, 2014 | Vizio VF550M 55 in. LCD HDTV
VIZIO VHT510. soundbar and subwoofer work. No sound from satellite speakers
Mar 06, 2011 | Vizio VHT510 Theater System
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Ink absorber full Canon MP210
(11/24)
<Service mode operation procedures>
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
(11/24)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print See APPENDIX 1:
SHIPMENT INSPECTION
PATTERN 1: PRINT
SAMPLE
2 times Green EEPROM print See APPENDIX 2:
EEPROM INFORMATION
PRINT
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
(12/24)
<Destination setting procedures>
At Logic board replacement, make settings for each destination.
button pressing
LED Destination Paper for defaulte setting
0 time Green No change
1 time Orange Japan A4
2 times Green Korea A4
3 times Orange US/Canada Letter
4 times Green Europe A4
5 times Orange Australia A4
6 or more times Returns to a menu selection A4
<Waste ink counter reset procedures>
At the waste ink absorber replacement, reset the waste ink counter for the replaced waste ink absorber.
Setting operation for the waste ink counter (The counter setting value is selected by pressing the Reset button.)
The number of the Reset button
pressing
LED
0 time Green Reset the main waste ink counter to 0%.
1 time Orange Reset the platen waste ink counter to 0%.
2 times Green Reset the Main & platen waste ink counter to 0%. (Reset
collectively.)
<Button / LCD checking operation procedures>
At Operation panel unit replacement, check the button / LCD.
1. When pressing the Stop button two times, the machine will be moved into an LED confirmation mode.
2. As often as the Color button is pressed one time, each LED is lit one by one, and the machine get in the mode in which each
button is acceptable.
3. As often as each buttons on the panel is pressed from the left to the right, the displayed number is counted up.
Pressed button Display
Maintenance 1
Fit to Page 2
SCAN 3
Paper size 4
+ 5
Black 6
Color 7
Stop / Reset 8
On / Off 9
4. When all buttons are pressed, [1] will be displayed. Then, LED[8.5 x 11 Plain Paper] and LED[8.5 x 11 Photo Paper] will be lit on
the panel, and the machine will be in a service mode menu selection mode.
May 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Vizio GV47LFHDTV10A No Video No Sound after "POP"!
change the main board first. if you're lucky this will fix the problem if not your inverter is dead.
Mar 03, 2009 | Vizio GV47LF Television
S9 nvr goes into paring mode
Hello,..... when pair the S9 you must press and hold down the power on button till the led flashes blue and red...at this point it will be in pairing mode....
Feb 09, 2009 | Motorola Mobility S9 Headphones
Service Mode
need to down load software for mp150 printer
Feb 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Vizio VHT510 Theater System Logo
111 people viewed this question
Top Vizio Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
