Question about Water Heaters
Replace ignitor in bradford hot water heater - Water Heaters
    Problem Solver:
  • 16 Answers
If it is a standard gas heater and has a spark ignitor hanging in the side of the gas control of is probably not the ignitor. Usually that is the spark tip inside the chamber. Clean it with emery cloth and spark should restore. If gas control has ignitor built in you will have to replace the control. Try cleaning the spark tip first. If you have a power vent you have to pull the burner out of the heater and replace the entire flame sensor/ignitor assembly.
Posted on Jan 16, 2014
4 Suggested Answers
SOURCE: I need an upper element for my Bradford White
Go to your local hardware store, i perfer lowes or ferguson's
Posted on Oct 08, 2009
bearsfan7538
  • 119 Answers
SOURCE: Bradford White LP water Heater Power vent ,flame keeps going out
flue is overheating make sure outlet is not obstructed outside and if not that you feel a good air flow coming from it
Posted on Nov 15, 2009
  • 5245 Answers
SOURCE: I need the basics for replacing a thermostat on a water heater...Bradford/White brand, model M250S6DS2 50 Gal, 4500 watt per element 240 voltage 50/60 hz. It keeps over heating even at lowest setting
Copy following link for replacing thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Suggest you might also want to test the elements while power is turned off, just in case the problem is element shorted to ground across metal tank to ground wire.
http://waterheatertimer.org/How-to-test-water-heater-element.html
At least you know the 240volt power to water heater and the circuit breaker are good.
Posted on Oct 01, 2012
How do I light my hot water heater?
It is pretty easy - make sure gas valve is open, change control know to pilot. Press the ignitor a few times and once pilot lights up switch control to warm or hot position.
See instructions by downloading manual for MI-403SF6BN from this site
Bradford White Water Heaters Built to be the best
Sep 15, 2014 | Bradford White Bradford MI403S6FBN-337 40...
My bradford white 50 gallon hot water heater Model # M250S6DDs NCWW Serial # E610822231 D/N
Depends on source of leak: If gas water heater is leaking from bottom, then heater must be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-water-heater.html
Add a comment and describe type of water heater, and what you discover about source of leak.
May 25, 2013 | Water Heaters
I have a Bradford White water heater (model# MITW50L6LN10) that started making noise yesterday. Tonight when the family got home we started a bath for the kids and surprise surprise no hot water left in...
Probably cheaper to fix existing water heater.
The problem might be the power vent, or the power vent might be short cycling because the gas control valve is bad, or vacuum switch has gone bad.
Call Bradford White and get their recommendation for your specific model.
http://www.bradfordwhite.com/contact.asp
http://www.bradfordwhite.com/supportserv.asp
http://www.bradfordwhite.com/findaserial.asp
Bradford White is very good brand of water heater
Rheem, Richmond, GE are good.
I prefer the AO Smith, American, State, Reliance, Craftmaster. Kenmore, Whirlpool brand since air intake screen is located on bottom of unit and can be inspected and cleaned without removing burner.
Feb 09, 2013 | Water Heaters
Too much hot water, how to adjust water temperature
1) Copy following links:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) if you have electric water heater, and too much hot water, then thermostat may be bad, or element is shorted and needs replacement. Test elements first, and if they're ok then replace both thermostats.
Jan 22, 2013 | Bradford White M240s6ds-1ncww 40 Gallon...
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
Jul 28, 2011 | Fasco Bradford White Hot Water Heater...
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
May 03, 2010 | Water Heaters
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
