My cnm touchpad 7 the screen went off unabling me
My cnm touchpad 7 the screen went off unabling me to even turn the power off now it's just black the light comes on when I plug charger in but nothing on the screen
  • Anonymous Mar 21, 2014
    i have a cnm 10.1 touchpad.when i turn it on the screen is different shades of white then grey and that is all i get on it.what is wrong ?
    Top Expert:
  • Computers & ... Master
  • 23,128 Answers
Could be the back light has failed. If you shine a bright light at the screen and can see something in the background, that is what it will be.
Posted on Dec 31, 2013
JSEhandyman
  • 368 Answers
SOURCE: My Gateway went black screen no lights what happened
Hi flady_98,
You don't specify model, so what follows is fairly generic. If you can provide more details, perhaps I can too.
If it's booting (start-up chimes/sounds), then I'd suspect the display (either the back-light, or perhaps the inverter/controller circuit board). Backlights require (in my experience) replacement of the display, likely more than the value of the laptop if it was a refurb (~$500 and up in my exp.). Inverter boards are less spendy, but you have to get the right one, and get it installed (how tech-savvy are you?)
If it's not booting at all, (don't hear the hard drive spooling up, etc), then we start looking at power supply issues and go from there. But I really need more details.
If I can be of further assistance, let me know, and include as much detail as possible (you should be able to load digital pictures onto this space using the toolbar above).
If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 22, 2009
  • 17 Answers
SOURCE: screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Posted on Feb 22, 2009
  • 2567 Answers
SOURCE: Was using my Hp Pavilion dv7 laptop, suddenly
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Oct 10, 2010
  • 6771 Answers
SOURCE: Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Posted on Apr 08, 2012
redy2rumbl
  • 56 Answers
SOURCE: I keep getting a beep when I turn the computer on....black screen...and nothing
If the computer is out of warranty, you dont have anything to loose. Have the northbridge and video chips re-flowed. You can do this using a heat gun, but
you have to be very careful not to destroy your board. This is a similar problem that XBOX360 owners were having with the red ring of death. These boards run very hot and over time and many cycles of heating up and cooling off the
chipsets separate from the mainboard and your computer becomes useless.
I dont have a board in front right now but if my memory serves me right place
the board in front of you so the hard drive connections are on the left side of
the board and the CPU socket is facing up. the 2 chips you want to work on
are just to the right of the CPU socket and just above the CPU socket. Be
sure to remove the CPU before you put any heat on these chips. Use circular
motions with the heat gun on HIGH. You may need to get some flux to put around each chip before doing this, but in my case I didnt have to. There was plenty there already. Computer worked for about 6-7 months after my fix and then needed the same repair again. If you want to see this done there are a lot of videos on the XBOX360 being done on youtube so to kinda give you an idea of how to do it. Might not be worth the trouble and you might be better off parting out the machine and just buy another one. Its all up to you, I hope this helps
I just bought a new system
Posted on Aug 24, 2012
Where is the reset button on mytablet2 from argos
  • Make sure the tablet is charged up to 60%
  • Turn off the tablet completely .
  • Press Volume + button , while holding Volume + button , plug in charger.
  • Release the volume + button.
  • Press Volume + again and press Power button to boot the CnM Tablet.
  • When Android logo appear , release the volume + button.
  • Press Power Button again and press volume + button , Recovery Menu will be appear .
  • Press the volume down and select "wipe data/factory reset"
  • Power button to select it
  • You will see "Yes - delete all user data"
  • Select "Yes"press "Power" button to select it
  • Formating will start. it will delete all user data .
  • Few seconds later, you should see the recovery menu again. Select reboot.
  • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
Dec 15, 2014 | Televison & Video
Why will my tablet not come on
Try with a new charger, probably the problem is in the cable, not in the tablet.
Sep 03, 2014 | HKC P776A - 7 8GB Dual Core Process
My daughters my tablet2 by bush has,frozen what do I do
if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
When Hard Reset is Necessary for Smartphones or Tablets ?
1. Forgotten Pattern Lock on Android Tablets or Smartphones.
2.Too many pattern attempts / Reset user lock.
3. Tablets PC,Smartphones stuck on Gmail account.
4. Android Tablet PC stuck / freeze on Android logo.
5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
6. Android market having problems or generating errors.
7.Upgrading to new Android version.
Make sure to charge battery upto 60%.
How to Hard Reset Argos CnM TouchPad Android tablet pc ?
you are done.
Jul 25, 2014 | Audio Players & Recorders
My Kocaso M736 tablet is not fully turning on. If it is not plugged in, the screen will stay black and won't turn on. If I have it plugged into the charger and press the power button and hold it, the
Sounds like your battery is shot. If it goes to far past dead, it will not power up even plugged in. Go to a battery store/Best Buy etc. and see if they have one you can use to try. Certain battery types can not go under 25% of a charge or they will not charge again correctly and vice versa. Just a short in the dark but hope that fixes your problem
Mar 07, 2014 | Kocaso BRAND NEW M736 7" High Resolution...
CNM Touchpad 9 frozen
Did you fully charge the product?
Dec 30, 2013 | Audio Players & Recorders
This alienware 14 laptop is newly brought, what i did is plug in the charger, turn on the laptop, while on the logging screen, the laptop screen suddenly went on and off and then finally, the monitor went...
this is a problem with the graphics its as if you have it on but no screen and you can still see stuff working I fix stuff like that all the time but if your not good with computers then this can cost you anywhere from 300-500 depending on the chipset I would post how to fix but I promise a lot of people would get mad its a trade secret I don't work at a shop per say I work with many and they all come to me with this issue hope this helps
Oct 25, 2013 | Alienware PC Systems Alienware M14X 140...
How to charge a cruz tablet r102
That happened to me about 2 hours ago. What i did was take the back piece of (be very carefull) and blow into the back. Then Plug the charger in and turn on the power put or oush the power button. It takes a little time because you have to keep trying. If the back is hot take the back cover off and blow on it also. If that doesnt work send me another message or a reply!
May 02, 2013 | Velocity Micro Cruz SE R102 Android Reader...
Latitude cpx screen went black and turned off
No i doubt she has done that matey.
try fiddling with the charger cable there might be a loose connection, fiddle with it until the charge light comes on then you will know what your problem is :)
hope this helps
Feb 16, 2009 | Dell Latitude CPX Notebook
My gateway mt6839b wont turn on anymore
Gateway was working good went upstairs came back NOTHING BLACK SCREEN....
My gateway screen was constently black every time I powered on nothing no bios, nostart up no warning..The board has indicating lights to follow the start up power light on, battery light on, then the disk drive....but thats it normaly the harddrive reader light comes on but nothing.... So detached every component and tested individually..... come to find out one of my 2 ram slots is damaged not the chips...this could be your problem..try
Skillz Unlimited MDA
Nov 20, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
