Question about Whirlpool WFW94HEX Washer
Wfw94hex f06 wont start
My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
Janice,
Here is a link to a website that gives the F06 code, but I cannot find the other code.
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
Scroll down towards the bottom to find the Duet fault codes.
Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
Why do I get the wrong code F06
If this is a Panasonic VCR F06 means that the mechanism locks after unload. It could be something to do with the loading motor, or since the cassette won't come out, the carriage the tape sits in.
Aug 19, 2014 | Televison & Video
Hello, I have a whirlpool duet wfw94hexlo washer. got an error code, drain filter assy., cleaned it put it together. when you go to start machine all seems normal. you push start, door locks, light comes...
Great! you have the MCU (motor control unit) need to replace. Removing the rear panel so you are able to see the motor and MCU. Replacement is easy, almost no screw on the board.
Oct 22, 2013 | Whirlpool WFW94HEX Washer
I suspect I need to clean the filter on my washer, but I can't figure out how to do this as there is no kickplate or seam. Where is the filter located and how can I clean it out?
Everyone says to pull the front access panel off but my WFW94HEX machine also had no front panel. I took the back panel off and accessed the pump filter from the back side. All the rubber hoses were also coated with mildew and I cleaned them all out as well (the connection from the drain to the pump, the air vent, etc.). The smell is reduced but not gone. Not hard to do but I suspect it will not permanently fix the problem.
Oct 23, 2011 | Whirlpool WFW94HEX Washer
F06 error
Unplugging it sometimes corrects the problem. However, it must be unplugged for SEVERAL minutes.then start it again i think it ll set it ok becuase sometimes it all sets it right.
or
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU, check your owners manual, some are covered under warranty for up to 5 yrs.
now check the CCU,MCU and Motor any one of these must be faulty that will only lead to F06 error.
Jun 19, 2009 | Kenmore 45087 Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool WFW94HEX Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
