Question about Cycling
What size steering tube is in roadmaster mt sport sx
3 Suggested Answers
  • 190 Answers
SOURCE: My daughters mt sport sx
phililisa03-
This problem is caused by improperly adjusted derailers/shifters, the mechanism that move the chain from one gear to the next. It is not uncommon for the derailers to be out of adjustment after sitting unused through the winter. Over time the cables that run between the shifters and the derailers stretch just a bit and the derailers no longer work as well without a little tuning up. Unfortunately, for the novice, adjusting the derailers is frustrating at best. The effort and patience it requires is nothing to take lightly. If you're game for giving it a try, there are a number of websites out there that will provide extensive guidance on the process - just "google" how to adjust bike derailers" and you will find plenty of options. My local bike shop will make adjustments like this for a small set price, around $20 or so - you may have a shop nearby that will do the same.
Hope this helps.
Regards,
DIYpro
Posted on May 03, 2011
dunnbiker
  • 8546 Answers
SOURCE: where can I get a
What exactly are you needing instructions for? Most bikes are just static frames with a bunch of aftermarket (Shimano, for example) stuff hung on them.
Except for proprietary frames or technologies, everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the individual manufacturers' websites.
Places like http://www.parktool.com/blog/repair-help document many of the repair and adjustment procedures.
Search Engines will find tons of How-to videos for assembly and adjustment if you just type in the basic question.
Any of the major cheapo bike manufacturers will have a basic or comprehensive generic manual. No one makes manuals for individual models unless they are unique.
Posted on Aug 10, 2011
Hi I recently bought a used roadmaster mt sport sx bike and the rear gear that's attached to the wheel is moves like in circles... is that supposed to happen... if not how can I fix it?
Lots of things on a bike move in circles. If you mean it moves when you pedal but does not "catch," so the bike does not move forward then that is a problem with the rear gear cluster. You need to have a mechanic look at it. If that's not what you mean you need to get help in providing a more clear explanation.
Oct 12, 2016 | Roadmaster Cycling
Do you have Roadmaster bike manuals
The only thing I can recommend is go to Walmart, ask them. Or look for a Roadmaster on their shelves, look for a website in the booklet hanging on thebike
Sep 29, 2014 | Roadmaster Mt Fury Bicycles
Replace rear tire
Remove rear wheel from bike. Deflate tube by removing valve stem. Tire should remove easily by pulling rim of tire over the rim. IF difficult, take to local bike shop for assistance
Jul 29, 2014 | Roadmaster Mt sport sx
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
My 2007 ktm sx
Carburetor is dirty, idle circuit needs service.
Jan 07, 2014 | 2007 KTM 125 SX
Where can I get a manual for mt sport roadmaster 18 speed bike
Aug 10, 2011 | Cycling
My daughters mt sport sx roadmaster bike keeps changing gears and making a clicking sound. What causes this?
phililisa03-
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Roadmaster Cycling
Can I raise up the handle bars on my 26" Ladies'
No, but a bike shop can assist you in selecting and fitting a stem with a higher rise.
Feb 24, 2011 | Columbia Sportswear Columbia 26" Ladies...
What wrench or crows foot and extensions do I use to remove the high pressure power steering hose attached to the rack and pinion? 1994 Buick Regal 3100cc engine
Wherever you can, you should use a tubing wrench, whether it is a crow's foot tubing wrench, or just a normal style wrench with a tubing wrench end.
Those fittings are tight, an you have no options left if you damage the fitting.
As far as what to use, it is always a game of Legos as you try to gain sufficient access with enough oomph to do the job. Use open en wrenches to find what the size is, then use what you learn from that to get the same sized tubing wrench.
If you are removing the hose, and you do not intend to use it again, it can really make things easier to cut the metal line close, then use a socket...
Jun 15, 2010 | 1994 Buick Regal Gran Sport
What are the wheel and tire sizes front and rear for my 99 883 sposter?
Tire sizes. Front 100/90-19
Rear 130/90-16
Wheel sizes front laced - 19 in.
rim width and contour - T19 X 2.5 TLA
Tube size - MJ90-19
Wheel size rear laced - 16 in.
rim width and contour - T16 X 3.00 D
Tube size - MJ90-16
Wheel diameter tubless rim front - 19 in
rim width and contour - T19 X 2.5 MT
Wheel diameter tubeless rim rear - 16 in.
May 26, 2010 | 1993 Harley Davidson XLH Sportster 883
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
