Question about Garmin StreetPilot c550 GPS Receiver
Jeco clock not working
OEM in 1994 Toyota Hilux
  • Jan Rey
    Jan Rey Dec 31, 2013
    Error on my part. My question has nothing to do with a GPS unit. I was reading about Garmin when I Joined Fixya. My question is how to fix or buy another Jeco digital clock as was installed in the 1994 Toyota Hilux. Thanks, Jan
I own toyota hilux 2kd d4d that has a morning cold hard start, after first start all is ok
Excellent answer... short & spot on...
(except YOU didn't mention "OIL CONSUMPTION")
toyota hilux 2kd d4d... Not getting a lot of domestic... (USA)
DIESEL information... here (sorry).
From Bill Boyd here in 1994"
Toyota hilux pick up D4D has hard start in the morning but ok after the...
Jul 24, 2016 | Toyota Cars & Trucks
Replace front shocks on Toyota Hilux 1994
Go onto YouTube and do a seatch there. Plenty of videos on shock replacement on trucks that will be similar to yours. It's easy to do.
Mar 29, 2015 | Toyota Hilux Cars & Trucks
Horn not working
what country, ??????? horns vary by country some have 2 horns.
it can only be 4 things. on all cars. 06 Toyota Hilux?
to find it only takes a voltmeter, any DMM set to volts.
a horn, (or is ground at base rusty)
the wires. (that includes connections )
the horn relay if fitted (FSM read horn page,)
and lastly the horn ring in the steering column.
any or all, only a voltmeter can find all problems all the time.
the clock spring is AIR bags, you defeat them when working
on the steering wheel in any way shape or form or risk neck snapping.
RTM read the FSM, manual. its all there.
so is it at alldata.com
usa
the Hilux name was retired in 1976 in favor of Truck, Pickup Truck, or Compact Truck.
read the confusion here, for GEN 7 pickups.
http://en.wikipedia.org/wiki/Toyota_Hilux
see why i cant find yours,? tocama., tahoma or hilux.
as you can see, no COUNTRY NO JOY
or
my motto:
NO YEAR
NO MODEL
No engine. (or transmission type A/T or M/T?, if that is in question)
NO HELP (or your joy)
Jan 08, 2014 | 2006 Toyota Hilux 3.0
Where is the fuse for the clock radio cig lighter in a toyota hilux 1993 model
Made a short circuit here radio, cig lighter ,air Con ,clock, windows, indicators are not working but hazards are working it is a toyota hilux
Oct 17, 2012 | 1986 Toyota Hilux 2200
Diagram for the timing of a toyota hilux 2.o vvti
get a Haynes manual. @$20 at autozone. money well spend as you will get lots of use from it if you work on your vehicle
Feb 15, 2010 | 1994 Toyota 4Runner
Rear drum brakes on hilux wont lock up when heavy brake on gravel
More than likely won't if equiped with Antilock system
Jun 09, 2009 | 1994 Toyota Pickup
1979 Toyota Hilux alternator wiring
always, counterclockwise starting with blue, then yellow, then red
Feb 21, 2009 | 1994 Toyota Pickup
Garmin StreetPilot c550 GPS Receiver Logo
41 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
