Question about Riverdeep Calendar Creator 9 Business Suite 9
How can I get back to my calendar that I was working on?
Error report: an attempt was made to access dock bar past its end. Can't open calendar I was working on.
Does this phone have a built in calendar. If so where is it and how do I access it
Hi
This phone has a calendar.
You can access it anytime by clicking on the dock at the bottom of the screen.
Regards
Jun 22, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cant open yahoo mail. it says Launch Empty Response
Thanks for visiting FixYa!
The error code, "Empty Response" is a problem known to Yahoo. And, they do not have a solution.
Sometimes there are ways to work around getting past the code. Some people report having luck - others do not.
Here's some suggestions:
1) Make sure your PC is not running any virus scans.
2) Attempt to access your Yahoo mail through a different browser, like Google Chrome or Firefox if you are using Internet Explorer, or 3) Clean out your browser's cache, browsing data and cookies, then restart your browser.
I hope this helps.
Feb 18, 2011 | Yahoo Mail
P1i, Calendar problem - Not enough memory
if its saying "not enough memory" u need to go to task manager and end all the open files you have multitasking. look up the top in task manager and u will see Recent and Open.
Mar 24, 2008 | Sony Ericsson P1i
Access 2003 Reports Error
open control panel. open ODBC Data source administrator. now look for anything with MS Access in any tabs. If you found none, then your registry is spammed and must be restored...try using windows restore utility [do this sequence: start-all programs-accessories-system tools-system restore. run it and look for a calendar date before your problem. If you had system restore turned off, the solution may be to attempt a re-installation of windows XP.] ... if you find some, then attempt to determine if they point to the correct sources (or drives).
Aug 17, 2007 | Microsoft Office Standard for PC
Unable to sync with outlook 2003
Try to change conduits to hotsync with PDS, if it will work then the problem is with the MSOutlook.
Sep 12, 2005 | Palm Treo 650 Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Treo 650 (cingular) and Outlook calendar
Its the substandard conduits that come with the 650. Hi - my issues were different than yours,but similar in that bottom line, my calendar data wasn't syncing correctly with Outlook. I've been dealing with this problem for the past 4 weeks. Sprint's technical support was useless, as was palmone. For 5 years, I have successfully synced my Palm Smart phone to palm desktop at home, and outlook at work - (4 different phones, 4 different companies). It dawned on me - for the past 4 palm devices, I was provided Chapura conduits... The 650 didn't come with them... GUESS WHAT. I bought Chapura Professional XT and all the issues I was having (they were too copious and too weird to go into here) were solved, in one measly synchronization. ALL of them. Don't wast ANY more of your time... Navigate over to Chapura's website and get one of the conduit programs -= trust me... You'll be glad you did.
Sep 11, 2005 | Palm Treo 650 Handheld
Delete calendar
Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Don't forget to change these settings back.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Unresolved Items when synching
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Sep 08, 2005 | HP iPAQ H2215 Pocket PC
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Sep 07, 2005 | Palm Treo 650 Handheld
Riverdeep Calendar Creator 9 Business Suite 9 Logo
Top Riverdeep Computers & Internet Experts
Bosse Photos
Are you a Riverdeep Computer and Internet Expert? Answer questions, earn points and help others
