Question about Android Apps
I have a brand new tablet and went I turn it on the only page I get says start ..I push it and nothing happens
My Proscan tablet wont start, I use my stylest tool push the start and nothing happens
JAN_yuanjia
  • 470 Answers
SOURCE: LG Model NTLG300GB wont turn on
check the power IC or the CPU, then replace it
Posted on Mar 31, 2009
wheelshot
  • 102 Answers
SOURCE: Brand new kenmore elite dishwasher won't start, does nothing.
May be a wire off motor compacitor. You can't see it from the front. The compacitor is facing the back of the dishwasher. You may have to un-install it to check or use a mirror and flashlight. It's located behind the motor on the left side looking from the front of the machine.
Posted on Apr 04, 2009
maxtreadmill
  • 832 Answers
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Posted on Mar 13, 2010
caroldon
  • 17130 Answers
SOURCE: brand new Whirlpool WTW4800XQ out
Before you attempt to do anything please check if the drum lock is removed, check the power plug, connect the water line inlet. and finally check the settings of the program.
Read through the manual and DO NOT ATTEMPT TO DO ANY REPAIR AS BEING A NEW SET you have warranty.
Call your dealer if the set hums even after the initial checks were done.
Posted on Aug 04, 2011
SOURCE: Will not turn on
Place it on its front on the floor and give the back a hit, then turn if on. The balls just got stuck. Fixed mine!
Posted on Feb 15, 2012
How do I get the message unfortunately com.android.phone off my sons proscan tablet?
Have you tried the reset with the paper clip in the reset hole yet.?
I think the reset hole is on the back. Press gently into the hole with a paper clip.
You will lose all data however and it will go back to factory default settings.
This is a common problem with Proscan tablets. Make sure you charge the battery fully before starting.
Jan 08, 2015 | Tablets & eReaders
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
Proscan tablet is frozen
Check for the reset pin hole on your tablet. Get a paper clip and push it 'gently' in the hole and hold it for thirty seconds. This resets the tablet.
Youdon't want to push hard as there is just a tiny button in there that can get dislodged.
Mar 02, 2014 | Proscan Recertified - PLT7035 4GB NAND...
I am trying to factory reset my irulu AK 303 tablet after it got locked on the too many pattern attempts page by holding down power and volume down but nothing seems to happen What else could I try
I am not familiar with your brand of tablet, but my Proscan 10" one has a reset button on the back. If you can find it listed in the owners manual or somewhere on the tablet, I would try that next.
Feb 08, 2014 | Tablets & eReaders
Kaser Android tablet will not turn on or charge its brand new
Did you drain the battery completely and try to recharge it? A lot of people have problems if they drain the battery and recharge. I went through 3 A300 tablets before I figured out I had to recharge the tablet BEFORE it went dead or it would never start again. I don't know why but many brands have this problem. Also, do not shut it completely off when it is on the charger. Always take it off charge, or turn off before charging. I had another prestige that had to be replaced because I turned it off or on while charging. I have not found out why this happens to many tablets! Good luck!
Feb 26, 2013 | Tablets & eReaders
My tablet goclever is not starting?
my on/off button wont work how do i open the back case of it?
Dec 21, 2012 | Computers & Internet
Belt wont start on a brand new Sole F80. Motor
Mar 12, 2010 | RTO Sole F80 Treadmill
Android Apps Logo
27 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
