Question about Apple iBook G3 Clamshell (M2453B) Mac Notebook
Airport card only works in same room as router
I have a g3 ibook blueberry clamshell i do have a airport card and i can be in the room with my router and the internet is fine but as soon as i go in another room it says i have signal but the internet basically drops. mind you my apartment is small and my dell pulls this fine no problem. is my airport card just gone bad or what? thanks
  • Apple Master
  • 4,338 Answers
Do you have a cordless phone in the apartment?
how many rooms do you have and in which room is the signal low? What router do you have?
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:
  • Router mfg'ssuggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the router may cause conflict with other routers within your network range. change the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 20, 2009
Cannot connect ibook g3 clamshell to internet using airport card
It's probably too old to use the current protocol of your wireless network. The G3 has been abandoned hardware for at least 7-8 years.
Dec 29, 2013 | Apple iBook G3 Clamshell (M2453B) Mac...
We brought a used ibook 3g and it will not play the dvd's and the videos on youtube keep freezing and won't hardly play. What can we do to fix this problem?
Unless it is a SE (special edition) one, it will not play dvds - it only has a cd drive. Tangerine and Blueberry models do not have dvd drives. Indigo and Key Lime models do. there are 2 different graphite models - one does and one doesnt. And youtube videos never play well on clamshells - they weren't designed for internet video. However youtube mobile (m.youtube.com) does work on the clamshell i've found. Good luck!
Mar 28, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
I cannot get my apple clamshell to recognize my wirelesss
In the iBook G3 Clamshells, Airport was optional. Are you sure you have one with Airport?
Dec 17, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
I have a ibook g3 clamshell laptop. I am trying
The G3 iMac clamshell speaks 802.11b wireless signal only. If your router is an 802.11n router, this symptom is known to occur, especially if you have any level of encryption (WEP, WPA, WPA2) on your router signal. Try temporarily turning the encryption off on your router and disabling N mode (set to G mode only) and see if this solves your problem. If so, obviously you don't want to leave your router unencrypted, but you may have to leave it set to G mode as long as you want your clamshell to be able to access it.
Nov 17, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Ibook g3
First of all, you need an Airport card for the iBook G3, chech for example this link; http://popular.ebay.com/ns/Computers-Networking/Original-Airport-Card.html (you should buy one like this: 9deeeda.jpg
, there is a G4 card too, but your iBook doesn't support this one).
Next, install it;
Then, buy a wireless router that uses 802.11b/g or 802.11b. This is very important because your airport card doesn't support 802.11g, and install it, but don't protect your network with a WAP password, your iBook doesn't support this, but use WEP.
Then start your iBook, and click on the Airport icon in the right corner, select your network, type in the password and it will work!
Jul 01, 2009 | Apple iBook G3 Mac Notebook
My clamshell ibook shows signal but won't load sites...
Try with Safari or Firefox. If still no pages loading then your Airport is not connecting to the Internet. If you are using a cable modem contact your ISP for assistance.
Jun 29, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Internet connection
Depending on what model clamshell you have will determine a few things. One thing to take into considertion is does it have an airport card in it already? I know it does not have USB 2.0 so a dingle is going to be super slow.
The original apple airport cards that went into most of the computers before like 94 or so are the same and will work in your machine too.
Getting to it is a little more of a chore. go to iFixit.com for a detailed directions to install it and they also have items like this for sale. Check on eBay for a known good working pull apple airport card delivered for not more than $75.
Peter
The OS mac osx has the drivers installed on it to support this device so does OS9
Apr 10, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Ibook G3 not conecting to internet
that just means it cant find it you need to try other setting and create a network connection,
it should see the network cable straight away try diff port on the router then dial up the ip address of the router first and change the setting . ip like 196.162.0.1
actionmab
Feb 24, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
MAC CLAMSHELL LAPTOP
Yes, you can use the ethernet 10/100baseT connector for high speed, the 56K modem for dial up or an optional Airport card for wireless
Jan 22, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
Apple iBook G3 Clamshell (M2453B) Mac Notebook Logo
301 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
