Question about Magic Entertech ED-9000 Mic Sing Along with 200 Songs Microphone
Where can i buy parts og my magic sing
Where can i buy parts of magic sing in the phillpines
We don't see the pictures in the tv
What models tv and magic sing model do you have?
Also where are you located and whre did you buy from?
Have you tried manufacturers?
Feb 01, 2013 | Magic Sing Along Consumer Microphone
HOw do I connect my Magic Sing to the Samsung wireless Soundbar and my Sharp LED HDTV to avoid 2 sec delay?
Which version did you buy? the latest version is ET23KH. I am on the waiting list at love2karaoke because the hindi version has not been released yet.
I used to have the ET19KV and my friend has ET18K, which are older models 2011 and 2009 respectively.
ET23KH supports HDMI connection with the cables included so that problem u should not have.
Which model do u got?
Dec 18, 2012 | Magic Sing Along Consumer Microphone
DELAYED AUDIO USING MAGIC SING ET23KM
Where did u buy this from? I have not heard of this model yet but I might be able to help.
Nov 08, 2012 | Magic Sing Along Consumer Microphone
I have enter magic sing i put it on a wrong voltage then the power supply regulator got burn how can i replace it. where can i buy iC76A and how much
It is likely soldered into the circuit board. It may be any of several part numbers such as 7805.
Try to read ANY number you can off the IC itself... the last two digits are the voltage... 7805, 7812, 7815 are common ones... There often is a production lot number... see if you can find the number ang et back to me as email.
Jan 21, 2011 | Karcher Enter Tech Magic Sing Mic Et-18kv...
Magic Sing ET-18k output delay
The delay is introduced by your high end HDTV. To alleviate this problem, connect the music part carried by the red and white wires a separate analog sound system.
May 15, 2010 | Magic Singalong Karaoke Consumer...
I have connected the Magic Sing to a HD TV and a home theatre system and now get a sound-lag between the voice and the sound on the home theatre. Any ideas?
You need to connect directly the sound wire of your magic sing to your home theather while the video wire of your magic sing directly to your hdtv. If its difficult to do because of distance, buy an rca extension to extend your magic sing wire to make it reach to the other end.
Dec 26, 2009 | Magic Sing Along Consumer Microphone
2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Aug 20, 2009 | Magic Sing Along Consumer Microphone
Change from PAL to NTSC
You need to configure it out.
1. Connect the magic sing in your TV
2. Turn on your TV
3. Magic sing should be Off
4. On your magic sing; Press and Hold "8" then while holding "8" press "power button", count for thre seconds then release both buttons (PAL to NTSC)
or
On your magic sing; Press and Hold "9" then while holding "9" press "power button", count for thre seconds then release both buttons (NTSC to PAL)
Mar 02, 2009 | Magic Sing Along Consumer Microphone
NO BACKGOUND VOCALS
Hi im joe,
Regarding your concern the ET 3000 magic sing does not have background vocals at all. The manufacturer design the magic sing for sing along purposes only but they are now improving there future products to have that feature with background vocals.
Feb 11, 2009 | Magic Sing Along Consumer Microphone
Magic Singalong Song Chips - question please
Not exactly, magic sing comes in different models with different song chip. Old magic sings uses Black with metal song chip, Black song chips, Silver song chips and Gray song chips.
For your Magic sing II (I believed it has four song chips slot) the compatible song chip is the Silver song chip.
Oct 26, 2008 | Magic Sing Along Consumer Microphone
Top Magic Audio Players & Recorders Experts
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
