Question about Hitachi 55HDS69 55 in. Plasma Television
Optical output surround sound from optical output?
How to hook up my surround sound to my insignia TV model nslcd26-09
You can use the optical output on the back of the unit to hook up to the input on the surround sound system. Via "Optical". That would be your easiest method of getting surround sound. You will need a optical line from somewhere like Walmart. Just ask for a 6ft optical cord.
Sep 28, 2014 | Insignia Televison & Video
Connect ps3 just sound to surround sound
PS3 has an "optical out" port. Use an optical coaxial cable (something like this one XO Digital Optical Cable 2m 2 Metre Premium Install Series suitable for... ) to connect this to an optical in port on your surround sound receiver/amplifier.
Go into the sound settings on the PS3 and set it to output dolby digital 5.1 from the optical connection.
Switch your surround amplifier to the appropriate source.
Feb 03, 2014 | Video Game Consoles & Games
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Does it support surround sound
Well not buit in, but it has a 92 KHz/16bit Audio DAC/96KHz/24bit decoder and coaxial digital audio output. So to get surround sound you need to connect the DVD player to your home theater receiver using the Digital coaxial/optical output connector (i.e. fiber Optic). Your home theater has to be equipped with the same type of input and you could enjoy your DVDs in surround sound soon.
Note: the optical inputs and outputs are generally capped when not in use and you will need to remove the the cap to be able to plugin your cable.
Good luck and please don't forget your thumbs-up to help me help you further. ty !
Apr 07, 2011 | Sony DVP-SR200P DVD Player
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
Hi there, is there a way to get my goodmans ghc58 surround sound system to play through my virgin + box? I cant seem to find an optical input/output from the surround sound but i do have a goodmans dvd...
There is an optical output from your Virgin + box but there is no optical input in the Goomans, there is only 5.1 input. The only way to do it is to connect the re and white phono audio output from you virgin box to the red and white tv inputs on the goodmans, this will sound good but it will not give you dolby digital sound.
Dan
Nov 28, 2009 | Audio Players & Recorders
Can older receiver support Hdmi with an adapter?
The optical cable will get you 5.1 surround sound - but only if the game has surround sound and your PS3 is set to output surround sound. Even the PS2 will do that. DTS is one 5.1 surround format and the optical cable will handle that too.
Check your settings on the PS3 and make sure you are:
Using the optical out, and
outputting a 5.1 surround signal.
I think you will find your JVC is adequate for this purpose. Please post back if you are unsure of how to set those options.
Jan 15, 2009 | Audio Players & Recorders
Hitachi 55HDS69 55 in. Plasma Television Logo
15 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
