How do I get a software program for Windows XP to Install on a PC that runs Windows 7
PC with Windows 7 will not let me install program that was made for Windows XP.
  • 39 Answers
Right click the mouse when the setup file is highlighted. Select compatability mode and choose win xp.
Posted on Dec 31, 2013
4 Suggested Answers
dongkikz
  • 440 Answers
SOURCE: Windows 7 WinExec failed: return=216 error
The program itself could be having problems with Win7
Posted on Apr 04, 2010
acdr
  • 1913 Answers
SOURCE: Not able to install any software on my PC having Windows XP
install windows instaler from here.
http://www.softwarepatch.com/windows/wininstallnt.html
Posted on Nov 15, 2008
  • 10 Answers
SOURCE: I have a Pfaff 2170 with a USB connection to my
If you have the original 3D file manager disk, the drivers are on there. In XP, With the sewing machine unplugged from the computer, insert the disk in the cd drive and explore the disk. Copy the "drivers" folder to your desktop. Plug in the Pfaff 2140/2170 to the usb port. Windows will ask for a driver disk. browse to the drivers folder on your desktop and open it, windows will highlight the driver it needs and click "OK". This worked on my wife's 2140 upgraded to 2170 software and you must always use the same usb port, or go through this routing again.
Posted on Jan 22, 2011
I have PrintMaster Premier 8.0, I would like to install on my computer running windows 7. It will not download. I do not want to purchase another version. Is there any updates that I can download to allow...
1. These instructions from Microsoft will explain how to run a compatibility troubleshooter for your software.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2. Contact Broderbund directly at 800-395-0277. I use their Print Master software also and they are very helpful at the customer service area.
Sep 11, 2013 | Mindscape PrintMaster Premier 7.0
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
Hi, I have used printmaster premier 7.0 for a few years on my old computer and have loved the program. The problem I am having is I bought a new computer that runs windows 7. I tried to install printmaster...
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
Sep 15, 2011 | Mindscape PrintMaster Premier 7.0
I cant install T-Shirt factory deluxe on mu computer windows 7
The following are your options for running this software:
1) Run your software in (XP) Compatibility mode - set in Program Properties-> Compatibility
2) Run in XP Mode if you have the appropriate version of Windows 7 (Professional and Ultimate) and Hardware (CPU must have Hardware Acceleration).
3) Install a Virtual Machine (such as the free Oracle VirtualBox) under Window 7 and then install an alternative Operating system (e.g. Windows XP) in this Virtual Machine and then the required software.
Hope it helps & Good luck!
Jun 12, 2011 | Nova Development Art Explosion T-Shirt...
I have original eyewitness encyclopedia space universe cd. but when i install it a error message shown in the computer. "[1058] the sound decompression software has not been install properly. please...
Hi ,
This product is not compatible with Windows 7 but it should run under Windows XP . If you are running under XP , I suggest you delete the program , reboot your machine and reinstall the program under Windows XP . If it still fails , you could need to reinstall Win XP or use the recovery disc . Launch the disc , select " install a new version of XP " and choose " repair " when you'll be asked to .
Make first sure you have installed SP3 and tested your program with XP fully updated .
Best regards ,
fanaudi .
Apr 22, 2011 | Dk Multimedia Eyewitness Virtual Reality...
I have the print master gold deluxe software and I'm not able to use it with window 7. please help
All you need to do is download & install Windows XP Mode for Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Once installed you will be able to run all your favorite old programs , if you run into any compatibility issues , right click on the .exe file & select "properties" , compatibility mode , & select the settings your program is known to work with .
After all this if you still can't run the program , try using " virtualbox " or " vmware virtual machine " & install a copy of windows xp as a virtual machine .
Apr 16, 2011 | Broderbund PrintMaster Gold 16 for PC
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
I have picture publish 7 cd but it will not load on windows 7
right click>properties>compatibility>change to another version of windows and run as admin. or rightclick the setup file on the disk and hit run as admin.
Dec 10, 2009 | Micrografx Webtricity 2.0 Full Version for...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
