Question about Sewing Machines
Stitching is loose and thread sometimes breaks.
    Champion:
  • 276 Answers
Check top (needle) thread tension
Posted on Feb 19, 2014
4 Suggested Answers
  • 25 Answers
SOURCE: The top thread is really loopy on the underside of
Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
Posted on Nov 19, 2009
WonderTech
  • 268 Answers
SOURCE: skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Posted on Mar 23, 2010
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
My sewing machine is lemeiux 7000 . My thread is breaking and Seam from the lower side is very loose .what could be the reason
It is a tension problem, check your needle to make sure it does not have a burr this will cause thread to break.
if the stitching is loose on the underside you have to figure out if it is the top thread going to the underside and making loops of thread, your tension is too loose so tighten ever so slightly and sew a few stitches till it is even, if it is the bobbin thread that is bunching up try re threading it and make sure you are using the same thread on both bobbin and top, some will not work together. hope this helps good luck
Jun 13, 2017 | Sewing Machines
When sewing, mechanism sometimes binds. Bigger problem is when finished stitching, the hand wheel binds completely. Is there a mechanical problem or someplace to insert oil?
Hello Griff
Very likely the thread is kind of bound up in the bobbin area. Just turn the hand wheel a bit forward and backward several times -after you lift the foot. Apply a gentle pull on the fabric and it should "break" loose. Often teh thread is still stretched around teh bobbin and this releases it.
Feel free to reply to this post if this does not do it.
Moses
Dec 07, 2014 | Singer 7436 - INGENUITY
I have the brother CE5500PRW sewing machine. I
Are you 100% sure you are using the right size bobbin?
Sep 11, 2017 | Sewing Machines
My top thread on my white sewing machine keeps breaking, the stitching is then getting snagged and bunched up underneath. In addition, I have noticed that the top thread is swinging loosely forward just...
try putting in a new needle---flat side to the back of machine
try rethreading the machine
make sure the top thread is on the thread take up lever
clean under the needle plate & in the bobbin area for loose threads & lint
Feb 06, 2012 | White Sewing Sewing Machines
I keep having problems with the stitching on my machine. 1) when you sew the stitches looks normal from the top but when you turn the material over it looks like one big tangled mess. 2)When it does...
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
Sep 26, 2010 | SINGER 7470 Sewing Machine
Bobbon thread is too losse /thread breaks no
Clean out the bobbin area.
Thread the machine with the presser foot up. This opens the tension so the thread can enter. Threading with the foot down closes the tension and the thread cannot enter as it should. When you sew, the top thread is loose and cannot properly connect with the bobbin thread to form a tight stitch. The stitching does not hold and pulls right out.
Thread breakage - top thread? Check the thread spool to be sure there aren't any nicks to catch the thread.
When the thread breaks, check the spool pin to see if the thread is unwinding too fast and wrapping around the pin. Thread nets can help stop this. You can find them at sewing machine dealers.
Mar 11, 2010 | Singer Sewing Machines
The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
Nov 19, 2009 | Craft Master 4300 Mechanical Sewing...
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
