Question about ASUS P5PE-VM Motherboard
Cmos check bad - ASUS P5PE-VM Motherboard
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
CLEAR CMOS BY REMOVE THE BATTERY 10-20 SECONDS.
BE GENTLE AND LOOK UP FOR ANY HOOKS.
Posted on Jan 01, 2014
Pxe-61 media test failure.check cable pxe-mof: existing pxe rom.loading drmk v8.00
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If your CMOS Setup has an option to boot from the LAN disable this option.
If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Then try re-booting and tapping the f12 key which should start up a diagnostics page
Mar 06, 2014 | Dell Vostro 3700 Laptop Computer PC...
Tip
CMOS Checksum error
Issue:
CMOS Checksum Bad or CMOS Date/Time Not Set
Cause:
This issue is caused when the CMOS values are incorrect. This issue can occur because of any of the below possibilities.
* Bad or old CMOS battery.
* BIOS update.
Workaround 1:
1. Disconnecting power from computer without shutting down computer.
2. Attempt to reboot the computer. If error still occurs after rebooting the computer enter CMOS setup and check all values, this includes verifying the time and date are correct. Once everything has been verified and/or changed make sure you save and exit CMOS setup.
3. If you have a Phoenix BIOS and have an option for 'Reset Configuration Data', set this value to 'Yes' and save and exit the CMOS.
4. If the computer was had the power disconnected while it was still running it is possible this could cause the CMOS to become corrupt. Ensure that the computer is ready to be shut off before turning off the computer. If you have a laptop computer ensure that the battery is charged before disconnecting the power connection.
5. If the CMOS values have become corrupted entering the values in CMOS setup and saving and exiting CMOS should resolve your issues.
Note: If this issue continues to occur after you turn off your computer off it is possible that the CMOS battery may be failing or already bad. Before considering replacing the CMOS battery try leaving your computer on for several days.
Workaround 2:
If you performed workaround 1 and the error occurs again after a complete power down (i..e. removing the power cord), the CMOS battery is likely bad. Most systems use a small coin style lithium battery. These often last 3-6 years, but at some point run out of juice and need to be replaced. For desktops, your system manual or motherboard manual should specify the type of battery and location on the motherboard. For laptops, it is often very difficult to access and may require a professional to replace it. To replace the battery on a desktop system:
1. Turn off the system and remove the power plug.
2. Remove the case or side panel to access the motherboard.
3. Look for a round silver coin cell, typically in a black holder.
4. Remove the battery while noting which way the battery is located. You may need a small flat screwdriver to release the side clip.
5. Install the replacement battery with the same battery type, being careful to insert it in the same direction as the removed battery (or using the polarity marked on the holder or manual).
6. Reassemble the case and power.
7. Turn on the power. You will get the CMOS Checksum Bad error once more, but it should be the last time. Go into the BIOS setup and set the date and time, and any other options you prefer.
on May 30, 2010 | Computers & Internet
The clock in my laptop losses time?
CMOS battery located on the motherboard is bad
Feb 06, 2014 | Compaq Presario C552US Notebook PC
Cmos Checksum Error
Check CMOS and Memory Modules:::If the error message is "UNEXPECTED_KERNEL_MODE_TRAP," then it indicates you have problem with the memory of your computer. You need to check whether the SIMMs (Single Inline Memory Modules) are compatible and have the same speed. Secondly, also check whether you have set the CMOS (Complementary Metal Oxide Semiconductor) to the right amount of RAM. If these solutions do not work, you might have to replace memory in your computer....try to use system utility tool like Reginout.. Hope the problem is resolved.
Apr 13, 2012 | IBM ThinkPad T43 Notebook
Laptop wont start
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
  1. Verify your boot options are properly set in CMOS setup. I recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
If this fixes the problem but it reoccurs again later you main need a new cmos battery. Or keep your battery always slightly charged.
Nov 16, 2011 | Toshiba Computers & Internet
No beeps,no cmos setup, its dead.
Not knowing how old it is, 2 things come to mind; a bad power supply or a bad CMOS battery. A bad CMOS battery would have failed to record the "last good configuration". Check the PS for any power at all ie fan turning, any lights etc
Aug 13, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Always display bad cmos setup
have you checked the jumper next to the cmos battery? check if its good not broken and also try and upgrade your firmware. visit your motherboard's manafacture for the firmware upgrade.
Nov 13, 2008 | Asrock P4I45GV R5 Motherboard
ASUS P5PE-VM Motherboard Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
