Question about Craig Televison & Video
My samsung model pn43e450a1xza has no rca outputs to match up to my craig model CHT921n sound bar
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Why is the sound on my new sound bar only going up half way?
Connect the sound bar to your cable box audio outputs--best way is optical. Then set the cable box volume to high and control the volume from the sound bar
Jan 12, 2015 | Craig Soundbar with Bluetooth
Does my RCA sound bar Model # Rts7110B-2 have bluetooth output for earphones?
The earphones and the sound bar have the same functionality: they are RECEIVERS of sound from an audio source, i.e you cannot connect one to the other (and anyway, what would be the point ?). You connect the soundbar to/with an A/V system, a TV, etc. You connect your earphones to/with a computer, laptop, phone, tablet, etc.
Jan 10, 2015 | RCA Televison & Video
I connect my I live soundbar to my Samsung plasma TV and I'm not getting no sound from the TV to soundbar please help
Check the TV's audio menu to make sure there will be signal available at the RCA outputs
Some sets won't allow both internal & external speakers/sound bar to both be on.
Jan 07, 2015 | Samsung Televison & Video
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no no outlet which fits audio aux which came with my Sanyo TV
Hook your sound bar to your output device, Cable Box, DVD/Blu-Ray player. Or try the follow should your Sound Bar have HDMI.
Output Device>Sound Bar>TV
The Sound bar should have a HDMI in and out or at least most Samsung models do as well as Bluetooth support.
It is easier to answer when you list the model of each Item, there are many different version of Samsung sound bars.
Jan 01, 2015 | Sanyo Televison & Video
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Connecting sound bar to proscan TV
Proscan has released hundreds of models of televisions over more than two decades, so I can't be specific without more information. There are also hundreds of different sound bars on the market. The answer given should apply to all situations:
Ideally, the sound bar should be connected to the television using one of the methods (in order of preference):
  • Optical cable output from the television into the optical cable input to the sound bar; (best)
  • SPD/IF coaxial output from the television into the SPD/IF coaxial input to the sound bar; (really just as good)
  • RCA R/L outputs into RCA R/L inputs to the sound bar. (not nearly as good as either of the above)
Jun 03, 2014 | Televison & Video
I have a samsung lcd tv that I am attempting to hook up a craig sound bar getting no sound out of external speaker
Check the settings on your tv. Many tv's need to have the internal speakers turned off in order for audio to be output from rear jacks.
Dec 31, 2012 | Craig Electronics CHT912 Bluetooth TV...
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Televison & Video Logo
29 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Henry  Thomas
Henry Thomas
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
