Question about Kenmore 23822 Top Load Washer
Won't spin or rinse, took clothes out .... too heavy maybe??
Kenmore 90 series top loading washer agitates, and won't spin, drain.
    Genius:
  • 1,122 Answers
You have a bad lid switch,you can by pass it,remove the switch,put the pos.neg. together with wire nut and your finished-mike
Posted on May 20, 2009
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series top load washer: won't agitate or spin
Sorry to give you bad news but this sounds too much like the transmission is shot. It's a bit of work to change and probably some luck to find one at a reasonable price, so my advice is to ditch this machine and get another. :(
Joe
Oct 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
331 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
