Question about Beckett A2EA6520 Single Stage Clean Cut Pump w/ PD Delay Timer
I have an oil burner that is leaking. how can i determine if it is oil pump or something else?
Beckett clean cut A2EA-6520
    Problem Solver:
  • 29 Answers
Do you see oil or water? If oil then the pump seal is broken and you need oil Tec to change the pump.
Posted on Jan 12, 2014
Beckett cb151ul will not turn on when there is water in the tray
I need more info. What tray has water? Where is this tray located? Is this a humidifier? If it is there a float switch that when it begins to overfill it shuts the system down. You realize that this is similar to trying to cut hair over a telephone!
Jun 09, 2014 | Beckett 21805U Oil Burner Motor
Im trying to replace the oil pump on a beckett burner i took out the 2 bolts holding the pump to the burner but the pump wont budge. the line is disconnected and it is stuck in place.
1. Disconnect fuel lines, remove two fuel pump screws.
2. Remove motor and coupler by taking out 2 bolts. Remove motor wires, if needed, to place motor on the side as you are working on the pump
3. Clean pump mount from inside burner with a rag. Spray WD40 to loosen any accumulated rust or dirt and clean again.
4. Using a flat nail punch and a hammer gently knock the pump evenly on the mount to push it out from inside the burner. Repeat it, if needed.
Mar 13, 2011 | Heating & Cooling
Honeywell Beckett Oil burner locked out.....just
how do you reset a beckett oil burner when your locked out ?
Nov 04, 2009 | Heating & Cooling
Beckett burner; I notice small particles of soot under stack vent
The soot can be caused by a number of reasons, if it was recently cleaned, I would wonder if the service tech just left a little mess behind. If you are reasonablely sure that is not the case, one cause could be a faulty pump. Inside the fuel pump is a pressure regulating valve, that is responisible for pump pressure and cut off. If the valve is failing, and not giving proper cut off, then a small amount of oil will drip into the chamber (called "after drip") and upon start up this oil burns incompletely causing a soot build up. A delay valve often masks the problem by providing the positive shut off electronically. Another problem/cause could be impoper adj. of the burner during the tune-up. On a final note, with equipment that old, it would be a good idea to start looking into a newer, more efficient system.
Apr 10, 2009 | Leviton White Decora Oil Burner Rocker...
Humming noise with my beckett burner
the beat i can do on this is an educated guess , it would be the pump or the pump motor bearings , but having said that i have also seen these make noise for years and not go out ,I have worked on oil burner about 35 years experience has taught me not to guess parts , so the advise i would give is to find the part and model numbers for the motor on the pump assembly and the pump try to find availability in your area , heating and cooling, hardware store ECT. and wait to see if becomes more defined or fails so you don't spend a fortune on parts you don't need ,**** make sure there are no oil ports on the pump motor bearings 9LITTLE OIL CAPS ECT OR PLASTIC PLUGS YOU CAN REMOVE TO OIL ) IF THERE IS PUT A COUPLE DROPS OF 3 IN 1 OIL AND SEE IF IT HELPS .
Feb 01, 2009 | Water Heaters
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Beckett home oil burner
problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Nov 01, 2008 | Water Heaters
Beckett A2EA6520 Single Stage Clean Cut Pump w/ PD Delay Timer Logo
190 people viewed this question
Top Beckett Plumbing Experts
Dave
bobalix
Gil Shultz
Are you a Beckett Plumbing Expert? Answer questions, earn points and help others
