Question about Juki Sewing Machines
Stitching is loose - Juki Sewing Machines
  • 64 Answers
Thread tension too loose or bobbin tension to tight or take up spring too loose. u did not state on which side the stitch is out of balance.
Posted on Apr 11, 2014
How do I fix loose stitches without having to start over?Loose on the left hand border. I now how 6 by 4 foot . Just learned how to crochet 3 weeks ago by watching a video. Help !!
There is no way to change the stitches without starting over, but depending on what it is you are making, you could incorporate the loose stitches as a design feature, for example by adding crochet over top of stitches like is shown in the video below.
https://www.youtube.com/watch?v=SFJ8-r7C2e8
Feb 20, 2017 | Sewing Machines
Disney embroidary pe18od loose stitches under work what am i doing wrong
Use a brand new needle that is best suited for the thread weight and type of fabric you are stitching.
All About Needles
Be sure that you ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disk so the thread will seat properly. Also, if it continues to have loose stitches underneath, tighten the upper tension.
Oct 18, 2016 | Sewing Machines
When I embroider with my Pfaff Creative 2 the top tension pulls bobbin thread up too much. I changed toe tension on top but it still does the same thing. How can this be fixed?
Suggest you do rethreading ,then test the stitches on straight stitch. If top stitches is loose you have to reduce the upper thread tension, if the bottom stitches is loose you have to increase the upper thread tension. Adjust accordingly till you can get a perfect straight stitch. If okay then you can continue your embroidery work.
Oct 31, 2013 | Sewing Machines
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
The underneath stitches are loose
When you see loose stitches underneath your sewing, it usually means that the top tension needs tightening. Write down where your tension disk is before you turn to a higher value, then sew. Keep doing the above until you reach the correct top tension. The reverse of this would be loose stitches on top which means the bobbin needs to have the tension screw increased, little at a time, about 1/8 ". Sew and repeat until the stitches are equal.
Sep 05, 2010 | Sewing Machines
The stitch is out of adjustment.top stitch is too loose
Check the upper tension unit for loose threads or fluff. This causes the discs not to completely close when the presser foot is lowered.
Feb 17, 2010 | Husqvarna Freesia 415
How do I adjust the bottom thread the stitches are too loose?
if stitches on top is loose then remove bobbin case and tighten small screw on it. if stitches on bottom of fabric is loose then tighten top thread tension.
Nov 03, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Stitching too tight on top
I found a screw on the bobbin case (where you put the cotton for the underside stitching) which was very loose. I tightened it and that created more tension for the bottom thread which solved the problem.
Jan 02, 2009 | Bernina Activa 130
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Sewing Machines Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
