Question about Beckett A2EA6520 Single Stage Clean Cut Pump w/ PD Delay Timer
Oil is leaking from the pump area of the motor. i have a Beckett A2EA6520 why would it leak? or could it be something else causing the leak?
I have an oil burner that is leaking. how can i determine if it is oil pump or something else?
Do you see oil or water? If oil then the pump seal is broken and you need oil Tec to change the pump.
Dec 31, 2013 | Beckett A2EA6520 Single Stage Clean Cut...
1994- Chevy Cavalier V6 3.1 engine - leaking oil problem. every 2 months I am replacing the oil because it leaks
it is probably the o-ring in your oil pump. I have the exact problem in my Cavalier. it is a little expensive to fix and I believe you practically have to pull the motor to replace it. Just keep oil in it and you might want to wash down the motor compartment area to cut down the oil spray areas. Don't use a cleaner that will make it too clean because with a motor that oil you may cause more leaks. Sometimes with an old motor you need the build-up around certain sealed parts to fill gaps because it is an older motor. I had that problem with my Old mustang may she RIP, i used a detergent oil because I was told to and it started leaking 3 - 4 qts. of oil weekly and didn't before I used the detergent oil.
Mar 11, 2012 | 1994 Chevrolet Cavalier
Coolant/Oil Leak... Big or Little problem?
I think that car has a transverse mounted motor. if that is the case, the area that you see coolant is probably coming from the weep hole on the water pump shaft. that is the precursor to a bearing failure. that is where i would look first. if you get coolant on the pass side floor of the car, then it would be the heater core. hope that helps.
Jul 20, 2009 | 1997 Dodge Avenger
Humming noise with my beckett burner
the beat i can do on this is an educated guess , it would be the pump or the pump motor bearings , but having said that i have also seen these make noise for years and not go out ,I have worked on oil burner about 35 years experience has taught me not to guess parts , so the advise i would give is to find the part and model numbers for the motor on the pump assembly and the pump try to find availability in your area , heating and cooling, hardware store ECT. and wait to see if becomes more defined or fails so you don't spend a fortune on parts you don't need ,**** make sure there are no oil ports on the pump motor bearings 9LITTLE OIL CAPS ECT OR PLASTIC PLUGS YOU CAN REMOVE TO OIL ) IF THERE IS PUT A COUPLE DROPS OF 3 IN 1 OIL AND SEE IF IT HELPS .
Feb 01, 2009 | Water Heaters
Oil leak after accident repair
oil filter Is a suspect actually... any oil cooler lines going towards the front front of oil pan etc... lift vehicle and look ccareful at all areas near damaged area ...good luck
Jan 04, 2009 | 1997 Toyota RAV4
Beckett home oil burner
problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Nov 01, 2008 | Water Heaters
Beckett A2EA6520 Single Stage Clean Cut Pump w/ PD Delay Timer Logo
43 people viewed this question
Top Beckett Plumbing Experts
Dave
bobalix
Gil Shultz
Are you a Beckett Plumbing Expert? Answer questions, earn points and help others
