Question about Sharp AR-M205 Copier
I need help regarding our scanner. Thanks.
When i'm scanned a A3 size document for a 600dpi there was an error message C..E.. then when i press the start button says "11". what should i do for this SHARP AR-M205. Thanks.
The problem is you don't have enough memory to scan A3 in 600dpi. You can either try lowering the dpi or add additional memory.
Posted on Jun 17, 2009
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
Changin the paper size for scanning
Most scanner devices will scan a document at the size of the scanner (A4, A3 Etc) If you want something smaller then open up the software that came with the scanner and you can Crop the scanned document to the size you need then save it in whatever format you need it in.
Aug 28, 2014 | Office Equipment & Supplies
How do I fix paper jam for AV122C
Sounds like the machine is picking up a signal from the paper exit sensor. The flag is not moving freely, or not moving at all. Look down in the paper hopper, ( where the paper is loaded), you might be able to see the sensor. The flag is spring loaded. Sometimes the flag falls off. The flag is black and shaped like a (T).
May 11, 2014 | Avision AV122 Color Duplex 18ppm/36ipm CCD...
When scanning printed document as an email attachment the print is not clear.
Scanning high resolution(600dpi). and reduce size 300dpi and compress image (image editing program format jpg.)
Mar 29, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I can't scan different document sizes (A3 and A4) in one batch with the Canon 9080C.
IF you are using CapturePerfect 3. version, you can select "Auto detection" for page size, and under 'more' select 'image size' instead of guide plate. Also you may have to select option '1' under user code U10 in case you want to scan pages over 17 inches long. (Press Newfile and Countonly simultaneously, press 'newfile' till you get U10, press 'countonly' and select 1. This will enable scanning upto 1 meter long).
CP3 has "Skip Blank page option", this helps you to automatically delete blank pages on the back side and scan only those with data.
S. Mohan, Chennai, India
Dec 03, 2010 | Canon DR-9080C Path-Through Scanner
Scanner initialization error -scanner does not stop moving to right. eventually stops but will not function.
Error messages might appear during scanning. Click here to see the document which was developed to help HP customers resolve these error messages.
Regards
Riztech
Aug 23, 2010 | HP PSC 2110 Color Printer
OpScan Insight 4 scanner error message
i have a problem in opscan4 insight
Problem;
top/bottom image quality
Mar 20, 2009 | Office Equipment & Supplies
Scan error with HP Photosmart C4480
Please try "Scanners and Cameras" which comes with Windows to see if you can scan images successfully from your scanner.
_______________________________
Catherine Sea
Dynamsoft | TWAIN ActiveX/Plug-in
Feb 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
The Scan Settings dialog box allows you to specify advanced settings for scanning.
Document Type
Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
Document Size
Select the size of document to be scanned.
Auto Detect: Detects document size automatically.
Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
Reference See the section below for details.
Scanning images Larger than the Platen (Stitch Assist)
When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
If not, some images may not be scanned at the correct positions and sizes.
You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
Select the resolution at which to scan documents. The following scanning resolution can be specified:
Text(OCR): 300dpi, 400dpi
Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
this should answer your question , feel free to post here agian if you need more help.
Regards, and thank you for using fixya.
Oct 23, 2008 | Computers & Internet
Sharp AR-M205 Copier Logo
69 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
