Question about Hammering
Change the control panel in the cab of ex200-5
What do I need to do to change the instrument panel
SOURCE: No instrument panel lights on 1995 Nissan King Cab
Ye, the dimmer switch still works.
I know this because, when I turn on the left direction flasher, the panel lights pulse dimly on and off with the direction light flasher.
Do I have a defective direction light flasher? if so where is it located?
Posted on Nov 25, 2008
morse008
  • 1111 Answers
SOURCE: Instrument panel and driver control not working on Ford Freestyle
check for relay switches
Posted on Aug 22, 2009
emissionwiz
  • 80668 Answers
SOURCE: fuse guide 1998 f150
go to the link below and then follow that to the Ford site, there select your year and model and download the PDF ownerns manual, all the fuse info is in the owners manual. it is free
http://www.edmunds.com/ownership/howto/articles/120189/article.html
Posted on Oct 28, 2009
  • 1149 Answers
SOURCE: instrument panel removal
I suggest you invest in a 1 year subscription to www.alldatadiy.com It is what I used when I disassembled the dash on my car, and is way better than a paper manual. Another tip is to keep some zip lock bags, and a sharpie handy, and seperate and label all hardware that you remove to help your reassembly
Posted on Nov 16, 2009
skychief2001
  • 21873 Answers
SOURCE: The A/C & heater control panel on the dash of my 2004 Dodge Ram 1500 Quad Cab aren't lighting up, The rest of the instrument panel & radio lights all work fine. Are there bulbs that I need
There are bulbs in the control panel that may have burned out, or the wiring connector could be faulty.
Posted on Sep 26, 2012
Testimonial: "Thanks so much! Guess my next step is to try to figure out how to get the panel out & check things out!"
2005 Silverado 1500 crew cab stuck in 4wd high?
How many buttons on 4X4 switch ? Or doesn't have any . What transfer case does your have ?
Transfer Case - NVG 149-NP3
Transfer Case - NVG 246-NP8
Transfer Case - NVG 261-NP2
Transfer Case - NVG 263-NP1
4X4 light saying lit ? Flashes ?
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel.
The NVG 263 transfer case features a three button shift control switch located on the instrument panel.
Need more info . Could have DTC'S - diagnostic troube codes
DTC B0790
DTC B2725
DTC C0300
DTC C0305
DTC C0306
DTC C0321
DTC C0327
DTC C0359
DTC C0374
DTC C0379
DTC C0550
Aug 26, 2017 | Cars & Trucks
The esp bas light is on my 2009 dodge 1500 and it won't start
An Electronic Stability Program (ESP)/Brake Assist System (BAS) indicator is standard equipment on all instrument clusters. The ESP/BAS indicator is serviced as a unit with the instrument cluster.
The ESP/BAS indicator gives an indication to the vehicle operator when the Electronic Stability Program (ESP)/Brake Assist System (BAS) has been activated. This indicator is controlled by a transistor on the instrument cluster circuit board based upon cluster programming and electronic messages received by the cluster from the Controller Antilock Brake (CAB) and the Transmission Control Module (TCM) over the Controller Area Network (CAN) data bus.
The ESP/BAS indicator Light Emitting Diode (LED) is completely controlled by the instrument cluster logic circuit, and that logic will only allow this indicator to operate when the instrument cluster receives a battery current input on the fused ignition switch output (run-start) circuit. Therefore, the LED will always be OFF when the ignition switch is in any position except ON or START. The LED only illuminates when it is provided a path to ground by the instrument cluster transistor. The instrument cluster will turn ON the ESP/BAS indicator for the following reasons:
  1. Bulb Test- Each time the ignition switch is turned to the ON position the ESP/BAS indicator is illuminated for about four seconds as a bulb test.
  2. ESP/BAS Indicator Lamp-On Message- Each time the cluster receives an electronic ESP/BAS indicator lamp-ON message from the CAB indicating that the ESP/BAS system has been activated, the ESP/BAS indicator will be illuminated. The indicator remains illuminated until the cluster receives a lamp-OFF message from the CAB, or until the ignition switch is turned to the OFF position, whichever occurs first.
  3. ESP Full Off Textual Message- Each time the cluster receives an electronic ESP Full OFF indicator lamp-ON message from the CAB indicating that the ESP/BAS system has been manually disabled, an ESP OFF textual message will appear within the cluster odometer display. The ESP OFF textual message remains displayed until the cluster receives a lamp-OFF message from the CAB, or until the ignition switch is turned to the OFF position, whichever occurs first.
  4. Actuator Test- Each time the cluster is put through the actuator test, the ESP/BAS indicator will be turned ON, then OFF again during the bulb check portion of the test to confirm the functionality of the LED and the cluster control circuitry.
The CAB continually monitors the ESP/BAS circuits and sensors to decide whether the system is in good operating condition and the proper outputs to the components of the system. The CAB then sends the proper lamp-ON or lamp-OFF message to the Electro Mechanical Instrument Cluster (EMIC) (also known as the Cab Compartment Node/CCN).
For proper diagnosis of the ESP/BAS system, the CAB, the TCM, the EMIC, the CAN data bus or the electronic communication related to the ESP/BAS indicator operation a diagnostic scan tool is required. Refer to the appropriate diagnostic information.
Apr 11, 2016 | Dodge Cars & Trucks
Ecm no bus?
sounds like you have a bad Body Control Module. Its the small computer that controls all the ground signals.
Dec 03, 2012 | 2002 Dodge Dakota Club Cab
Wipers dont work, washer fluid does. not the motor, followed wiring to some sort of circuit board behind glove box
The Wiper Control Module is located behind the RH side of the instrument panel, near the top of tthe cowl panel.
Jul 14, 2011 | 1994 Ford F350 Crew Cab
What does service 4 wheel drive mean
For the 4WD light, there is a TSB that instructs the dealer to replace the AC control in the Instrument Panel. The AC control in your truck is sending some incorrect messages via the vehicles data bus. The Instrument Cluster thinks it should turn on the 4X4 lamp. The new AC control will keep the 4X4 lamp off and you should not notice any problem with the AC
May 23, 2011 | 2003 Dodge Dakota Club Cab
2001 fronteer crew 4x4 dash lights
Check instrument panel fuse first. It would be labled on the fuse door or in manual. If not blown i would suspect the dimmer switch. There are to many bulbs in a instrument panel for them all to blow at one time.
Feb 15, 2009 | 2001 Nissan Frontier Crew Cab
Nov 24, 2008 | 1995 Nissan King Cab
Hammering Logo
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
