Question about Panasonic Sa-ht70 Home Theater Receiver 5 Disc Cd Subwoofer Speakers Remote Vg
Fg1 code shuts sound system down
What does the code fg1 mean?
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: panasonic home teather FG1 code apears when it
It's "F61". tha tusually means it senses a short on its output.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 07, 2011
dunnbiker
  • 8546 Answers
SOURCE: shows FG1 code then turns
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 26, 2011
dunnbiker
  • 8546 Answers
SOURCE: f61 or fg1 my sa-ht810v
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 30, 2011
When I turn on my Technics DV290 stereo it shows FG1 what does that mean.
Codes are not listed, you would need the troubleshooting manual, which they do not give the public access to.
Jul 09, 2017 | Technics Audio Players & Recorders
FGI on screen (Technics SC EH600)
I'm not sure what you are referring to when you say FGI, but if the unit turns off soon after it comes on, your unit probably has DC Offset, which means you have a damaged amplifier. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 25, 2013 | Audio Players & Recorders
Window washernopowertopump
no year , no joy. no answers.....
front or rear. guess at front.
no power, meaning you checked 12vdc at the front pump while active.
yes, then the fuse is blown
or the switch is bad,
or the wires and connections are bad.
post year and get 10x better answers.
even more if you tell body style
ive not a clue... see wiki data. see the vast numbers of civics.
note, even you country adds 10x more data.
Contents
Aug 27, 2013 | Honda Civic Cars & Trucks
Panasonic home teather FG1 code apears when it turns on
Feb 07, 2011 | Panasonic Audio Players & Recorders
Fault code fg1
If it's a panasonic the number are f61 and means the audio amplifier's IC's are damaged and need to be replaced
Feb 02, 2010 | Audio Players & Recorders
Hometheater system doesn't power up
A Panasonic? Most likely it will need an output ic or a voltage ic. It could be just a stuck fan (rare). F61 is a voltage error code.
Oct 21, 2009 | Audio Players & Recorders
BATTERY
When it comes to this matter,If it isn't the snoy battery problem,then it must be the problem of sony camera charger.
For the NP-BG1 problem,you can refer to this website for help information.
Sony NP-BG1 , Sony NP-FG1 ,np-bg1 digital camera battery charger
Jan 06, 2009 | Sony Cyber-Shot DSC-W7 Digital Camera
Panasonic Sa-ht70 Home Theater Receiver 5 Disc Cd Subwoofer Speakers Remote Vg Logo
22 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
