Question about Hitachi CP-X1250 Multimedia Projector
Factory reset my menu is in chineese
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
Factory reset
There is a "Reset Factory Setting" menu button in your Change Preferences menu that you can select to restore your GPS to factory setting.
If you can't seem to find it, make sure you have all your menu options shown ... by selecting "Show All Menu Option" button first.
Apr 24, 2013 | Tomtom GO 920 GPS Receiver
Forget my phone lock code for nokia n8 china
HI DEARIF YOU FORGOT THE PHONE LOCK CODE OF A CHINEESE PHONETHE ONLY WAY TO RESET THE CODE IS USING PROFESSIONAL CHINEESE TOOLOS LIKE GPGDRAGON BOX OR VOLCANO BOX
May 01, 2012 | Cell Phones
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
I HAVE A CHINA MOBILE A950 WHEN I ENTERED 1122 CODE IN RESTORE FACTORY SETTING OPTION EVERYTHING IS VANISHED EXCEPT INCOMING CALLS NO MENU NO DIALLING ONLY CHINESE LANGUAGE IS DISPLAYED WHAT SHOULD I DO...
HI I too have the same problem, when i reseted to factory setting.. the phone re-started and not able to go inside... something it is showing in chineese language.... any solution... pls
Sep 11, 2009 | Cell Phones
Keys are not working. But touch screen is working
r u checking restore factory seting
factory setting password 1122
May 22, 2009 | Sony SPP A968 Cordless Phone
Cect i68+ multimedia menu not working
These are some functions can be used on Chinese networks only. Just forget them.
May 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Was stuck on chineese, must,change language on lm 4800
You'll need to reset the factory defaults.
Download the User Guide (PDF) from here:
http://www.lexmark.com/publications/pdfs/2007/4800/en.html
(I'm assuming you have the something in the 4800 series of printers, though you posted your question in the 5400 series section)
Go to page 56&57 and follow the directions there.
If you have the 5400 series, the link is here:
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
See page 123.
Apr 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
CHINEESE MENU WITH ERROR D350
ftp://207.18.56.26/software/BPG/UserGuideC250PFW_G4.pdf
click on the above link for your printer manual.
if the above link doesn't work, click on this link...
http://kmbs.konicaminolta.us/content/support/supporthome.html
hope this helps!
Jun 16, 2008 | Konica Minolta bizhub C250 All-In-One...
Hitachi CP-X1250 Multimedia Projector Logo
35 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
