Ac showing f8 and will not work newclime model
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Oct 06, 2014 | Computers & Internet
Error F8 on a Frigidaire AC model FASE24C6****
Good Afternoon Konrad,
I understand that you are receiving an F8 error code on your Frigidaire air conditioner, model# FASE24C6. I also see that it will work for hours before displaying F8 or sometimes only minutes before displaying the error code. The F8 tells me that there might be a key stuck. I suggest resetting your air conditioner, by unplugging it for 3-5 minutes. Plug your appliance back in and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire Heating & Cooling
If ac show F8 What we can do
what a/c unit do you have. need the make and model number to help you.
Jun 08, 2014 | Heating & Cooling
My split ac is showing f8 on digital screen
Need to add some details, what kind of system do you have? Suggest starting by reading the owners manual, either the paper one or one Google shows you on line.
Dec 28, 2013 | Heating & Cooling
I have a voltas vertis AC ! It's showing me a F8 error the AC just won't work however the remote is working
please call their help line with this issue as i have not seen that error code before and i suspect it's a bad controller board.
http://www.voltasac.com/index.php?option=com_forms&view=pages&layout=contactus&Itemid=62
their numbers are 1800-425-4555 and 1800-266-4555
good luck.
Oct 14, 2012 | Heating & Cooling
My videocon split ac is showing f8
my split ac is showing f8 on the digital screen
Aug 04, 2012 | Heating & Cooling
Onida split ac show only f8 in display. how to slove the problem
That code is usually a result of a leak in the system and the unit being low on charge...find/fix the leak and recharge the unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air ConditionerTrouble -Review the Possibilities
heatman101
Jun 21, 2011 | Heating & Cooling
We have electrolux ac 1.5 ton i n our ac display showing F8 it is not change in remote how remove that.
Jun 17, 2011 | Electrolux Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
