Question about Symbol LS2208 Handheld
Scanner keeps restarting
Scanner will boot up and work but at random times shut down then reboot again at random
My iphone 6 keeps rebooting, I've already done a hard reset several times and a safari clear history, no good
hi Vardi.
i know you have said you have done a reset but this is all i could find out.
To perform a hard reset, hold the power button and Home button (the circular button below the screen) at the same time until your iPhone screen goes blank and the Apple logo reappears. ... People were amazed when they'd come into the Apple Store and I'd quickly fix their deadiPhone with a hard reset.22 Sep 2017
Why Does My iPhone Keep Restarting? Here's The Fix!
https://www.payetteforward.com/why-does-my-iphone-keep-restarting-heres-the-fix/
Why does my iPhone keep restarting itself?If iPhone iPad Keeps Restarting Randomly. You can restart or force-restart youriPhone iPad to clean all processes, which may help you fix "keeps restarting" issue. To force restart one device, just press and hold both of the "Sleep" and "Home" buttons at the same time for 10 seconds until Apple logo appears on screen.
What do you do when an Iphone keeps turning on and off?To do so go to settings ? Cellular/Mobile ? Turn On/Off Mobile Data. RebootiPhone: To reboot your iPhone, hold the power button and home button simultaneously for a few seconds. The Apple logo will appear on the screen and your iPhone is rebooted.24 Mar 2014SOLVED: My iPhone keeps rebooting/shutting down by itself? - iFixithttps://www.ifixit.com/Answers/.../My+iPhone+keeps+rebooting-shutting+down+by+itse...Search for: What do you do when an Iphone keeps turning on and off?
or go to this link.
iphone 6 keeps rebooting Google Search
Dec 02, 2017 | Hard Computers & Internet
Samsung turns off
It's faulty, buy an iPhone. You are not alone
How to fix Samsung Galaxy S4 that keeps turning off on its own ...
https://thedroidguy.com > Mailbag
Aug 24, 2015 - We received several emails from Samsung Galaxy S4 (#Samsung #GalaxyS4) owners whose phones are randomly rebooting. It may be ...
Fixing The Samsung Galaxy S4 Turns Off Does Not Turn Back On Issue
https://thedroidguy.com > Mailbag Jan 24, 2016 - The #Samsung Galaxy #S4 has established itself as one of the most dependable smartphones available in the market today. This device which ...
Samsung Galaxy S4 Randomly Shuts Down Issue & Other Related ...
https://thedroidguy.com > Mailbag Jan 10, 2016 - My Samsung s4 mini was switched off during an update and will not switch on now. ... Reinsert just the battery then check if the phone turns on.
samsung galaxy s4 turns off but still has 30% battery life ...
https://forums.androidcentral.com/samsung-galaxy-s4/303065-samsung-galaxy-s4-tur... Oct 12, 2016 - 25 posts - ‎22 authors
My s4 turns off at 30% battery life! ... note that, yesterday after the phone turned off by itself by showing battery critically low (in reality it had over ... Galaxy S4 shuts down randomly
8 Jan 2017
Galaxy S4: HELP with Hands Free
17 Dec 2016
Galaxy S4 Turns Off by itself sometimes
14 Apr 2016
S4 won't turn on unless replacing battery, then turns off ...
17 Jul 2014
More results from forums.androidcentral.com
Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ' Technobezz
https://www.technobezz.com > Tech -How To's > Android Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ... the battery. Now turn on the device to see if the sudden shut-off or reboot issue is resolved then. Samsung s4 mini turns itself off Google Search
Oct 28, 2017 | Samsung Galaxy S4 Mini Duos GT-I9192...
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
I need to reboot my laptop but i don't know how
Reboot essentially means restarting the computer. This is two types
1. Warm Reboot: where you go to start on windows task bar and choose shut down but when prompted choose restart. This way computer shuts down momentarily and restarts!
2. Cold Reboot: By this means you choose to shut down and again when prompted choose shut down! This makes computer off completely until restart by pressing power button.
Booting is computer Lingo for above procedures!
Oct 02, 2011 | Compaq Presario CQ56-115DX Laptop
Laptop randomly shuts down and shows a blue screen saying
Make sure you don't have any unecessary programs loading up into windows when your laptop boots up. The next time the system randomly reboots check to see if the laptop feels a bit warmer then normal. Could be that your air vents are being blocked by dust. That would cause the air not to flow properly. Take a can of air and blow the vents clear so the air can flow properly and that would take care of the problem.
Jul 05, 2010 | Gateway CX2618 Notebook
My laptop as randomly started shutting down on its
Put you Vista DVD in the drive & boot off of DVD, and when you see the menu select Startup repair... leave it go on through it's process and reboot when told , this should repair your startup issue, otherwise get back to me.
Feb 18, 2010 | Compaq CQ60-215DX Notebook
After running full system recovery I tried to reinstall my printer and scanner. I reinstalled my printer (HP Deskjet 870ces). Then tried to reinstall HP Scanjet 5100c on a machine running Windows XP Pro....
Some time printers and scanners conflict. Try this, uninstall both printer and the scanner, then install the scanner first and try it to see if it works. Then install your printer. If it doesn't work let me know I'll walk you through. Good luck :)
Feb 21, 2009 | HP Office Equipment & Supplies
Virus...need to reboot
hi.. shut down ur system. re start again. hen ur computer restarts keep pressing F1 key. it will auotomatically guide u to the re boot process... the F1 key is also called as boot menu key..
pls rate me
Jan 21, 2009 | Averatec 1000 Notebook
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Symbol LS2208 Handheld Logo
65 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
