Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Defrost drain clogged in an LG LFX25971
I need to know how to remove the rear freezer panel on the back wall inside of the freezer to get to the defrost drain. Please advise. Thanks.
  • 210 Answers
SOURCE: LG Refrigerator LRBC22544st
Take off the back panel and cut the insullation as in the photo and this will never happen again. What happens is the water gets trapped and then ice forms and builds up and causes the blockage.
Posted on Jun 11, 2008
  • 31 Answers
SOURCE: Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Posted on Jun 30, 2008
  • 9 Answers
SOURCE: Very loud clicking noise from my LG LSC26905TT refridgerator
first you have to remove all shelves in the freezer,then remove all screws in the interior rear panel. In some cases you'll have to remove a couple of shelf tabe located on the side wall. Once tha panel is removed,the fan will be in plain sight. The blade is usually aboue 4-5 inches in diameter and is attached to a small motor with 2 wires and a green grounding wire. Note: you might want to check why it's making noise. Is there ice built up around the blades?Are you getting too much moisture entering the box thru faulty door gaskets?
Posted on Aug 26, 2009
Testimonial: "It was very good advise."
  • 66 Answers
SOURCE: LG Frige builds up ice in bottom of freezer.
though this qestion is old, it might help someone
Here is a fix with images
Have fun
Avi
Posted on Jan 13, 2011
  • 66 Answers
SOURCE: There is water pooling and
defrost is OK, but you need to be sure you defrost the water drain outlet !
see this page with images that might suggest the fix.
Have fun
Avi
Water running down inside back panel of freezer and pooling on bottom and freezer and ice maker not making ice like it should
Sopunds like the defrost condensate drain opening behind the rear wall of the freezer is clogged with ice or gunk or both. All that water is causing something simular to a defrost problem and causing the freezer not to cool as well as it did before. That will affect ice production! What is the model number of your refrigerator? I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Apr 11, 2013 | Refrigerators
I have ice forming on floor of freezer. Kenmore Coldspot model 106.64244400, our research says we need to defrost and remove back panel to clear the drain, but we have no idea how to remove the panel. ...
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
May 10, 2012 | Kenmore Refrigerators
Ice forms on all of back wall
If ice is forming on the rear wall of freezer I would think that your refrigerator is not defrosting and temperatures inside the fresh food compartment will be rising soon. If ice is flowing from the base of freezer I would believe that your defrost drain is blocked and will need cleaned out. In this case I believe that most likely reason is the Click Here=> WR51X10055 Defrost Heater Assembly
has failed and will need to be replaced. If working on the defrost heater it is not a bad idea to replace the defrost thermostat=> WR50X10068 Defrost Thermostat
If this is the possible problem manually defrosting the evaporator coils with a hair dryer will be needed to keep food fresh and also be able to see the parts once the rear panel of freezer is removed. Unplug and remove the rear panel of freezer to expose the frosted over coils. The defrost heater and defrost thermostat are labled 230 and 240 in this photo here=> PSW26PSSBSS Freezer Components If I missed anything please let me know and should you have questions I will also be here to answer them for you, Thanks Sea Breeze
If helpful please rate this solution.
Oct 21, 2011 | GE Profile PSW26P Stainless Steel Side by...
Water dripping from freezer into refrigerator
Hi,Most likely the drain in the freezer is clogged up and frozen. Every time when your fridge automatically defrosting defrosted water dripping inside the fresh food compartment. You have to remove the back panel in the freezer and using a hair dryer defrost the drain which is located under the evaporator coil. Then put very hot water through the drain until it goes free.
Yes, you need to remove the back panel inside the freezer, It should have screws that come out then it should pull off and out.
On your model, the defrost drain hole/line is located inside of the freezer behind that back access panel, just remove that back panel, remove your freezer floor panel FIRST(Has 2 screws in front), that simply pulls out, then you will see the drain hole under the evaporator coil. It may be iced up, you will have to clear all of the ice and run hot water down the drain hole.
Once the back panel screws are removed that panel should just pull off, pull hard. Make sure your refrigerator is unplugged first.
Good luck.
May 28, 2011 | Kenmore Top Freezer Refrigerator
Water leaking out the bottom of the freezer even when water is shut off
The defrost drain is clogged causing the water from the defrost cycle to flow down to the freezer floor. The defrost drain and drain trough are located behind the freezer panel at the back of the freezer wall inside. Remove this cover to get to the defrost drain and remove ice. Do not use any thing that may puncture or damage the evaporator coils because this is what you freon flows thru to do your cooling. Thank you for using fix ya.
Feb 04, 2010 | GE Refrigerators
My GE side by side refrigerator is leaving a puddle on the floor in the morning. There is also a frozen puddle on the bottom of the freezer. What might be wrong?
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number .
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Sep 02, 2009 | Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
I noticed water inside my LG (Model No. LRTPC1831W) frdige. I think there is aleak inside the fridge. How can I fix this problem?
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 20, 2008 | Refrigerators
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
60 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
