Sony Vaio PCV-7752 case removal
How do I remove the entire case?
  • Mick Shayne
    Mick Shayne Jan 03, 2014
    I was able to remove the right side very easily which gives access to most of the normal things I would need to get to mess with. I need to change the power source so full access would help greatly.i know it's old but I'd really like to access the data on the hard drive.
myob247
  • 1342 Answers
SOURCE: trying to open the case for Sony VAIO PCV-RX540
Go Here
Scroll down to Overview & General Info
Posted on Apr 25, 2008
  • 16 Answers
SOURCE: CD/DVD ENCLOSURE in Sony Vaio PCV RX860
http://esupport.sony.com/US/perl/tutorial-display.pl?tut_id=269&mdl=PCVRX860
this link is a tutorial of how to get the side panel off,
to get the cd drive out, you need to do a couple more steps.
first, you will need to take off the top and other side panels. this can be done by looking at the top back of the case. there are two clips that hold the top panel on. push up on the two clips and the top part will slide back and you can pull up on the panel and it should come off.
Next, you should be able to push some more clips on the top to get the side panel off. it should fold down just like the first side.
then, you need to take off the front two panels. the bottom part should be just a couple clips on the inside front of the case, and the top clips will be revealed when you take off the bottom part.
after that is done, you should be able to unscrew the cd/dvd drive from the case and unplug the cables connected to it from the top where you removed the top panel.
then you should be done
Posted on Jun 05, 2008
Smoking_gnu
  • 38 Answers
SOURCE: Replacing the powersupply on a Sony VAIO PCV-RS720G desktop
Hi There,
From the looks of things that model will take a standard ATX power supply which would be available from and computer part dealer and ebay etc, get yourself a nice 400w replacement try and get a small form factor one if you can as it will be a tight sqeeze inside the case.
when replacing it you will have to open the case up (get an anti static wristband if you can, and work on a table rather that a carpeted floor) un hook all the connectors the old power supply (one in each drive and there should be 2 in the motherboard) you may have to pull the Dvd rom out slightly to get the new supply in, unscrew the 4 case screws holding the power supply from the back of the case. lift it out then put in the new one, screw it in using the case screws and connect up the internal power cables to the drives motherboard and new graphics card, close the case, plug in and voila
If you get stuck just ask and we will help
Posted on Dec 10, 2008
  • 565 Answers
SOURCE: How can I remove the
http://www.retrevo.com/support/Sony-PCV-RX470DS-Desktops-manual/id/751bh234/t/2/ u can find the manual here
Posted on Dec 26, 2008
Dr Geek MD
  • 201 Answers
SOURCE: how to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
Posted on Jun 02, 2009
I want to upgrade the mother board in my Vaio PCV-RZ44G Desktop so that I can run Windows 8. What board forms are compatible and is an Intel I3 or I5 CPU better?
You would be better off applying the money to a new computer. You are opening "Pandora's Box" . You will end up with a old case with ALL new components. That may or may not work, A.K.A., "pain and heartache".
Jan 07, 2013 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
How to dismantle sony vio desktop
This model simply requires the removal of the purple screw in the back side of the pc. Then, the side of the case would pull towards you.
Nov 07, 2010 | Sony VAIO Digital Studio PCV-RX660 PC...
How do I remove my DVD burner for replacement from my Sony VAIO PCV-RS720G? I get the two little screws out from the side, but then something hangs it up. Can't find what the hang up is. Thanks. Segalhund...
Segalhund, I appreciate your wanting a solution, but please refrain from stating your email addy.
There are three screws.
Facing the back of the computer.
One at the Top in the middle of the case cover.
One down on the Right side, straight across from where the monitor plugs into.
One down on the Left side straight across from where the monitor plugs into.
The cover is shaped like a hood, and slides towards the front of the computer.
I'm looking at the User Manual for the Sony Vaio PCV-RS720 Desktop PC right now.
This is Sony eSupport, and the download page for the Vaio PCVRS720G User Manual,
http://esupport.sony.com/US/perl/model-home.pl?mdl=PCV-RS720G&region_id=1
On this page left-click on Manuals, Specs, Warranty. (In blue to the upper right of the page)
On this page under the heading - Manuals -
left-click on - VAIO User Guide - in the list.
This is a PDF file. It may take as much as 30 seconds before you see the first page. Suggest you let it download all the way before looking through it.
Page 87 shows removing the cover.
Mar 28, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
I need to replace the DVD disk drive on my Sony VAIO PCV-RX580. I was able to remove the left side case cover but cannot figure out how to remove the other panels. Can you give me some assistance? Thanks -...
I also have a sony vaio but in replacing my drive I only had to remove the one side and two screws. Then push the drive from the front. the drive is "clipped" in there." It will come loose and just remove and replace. Good Luck
Mar 24, 2010 | Sony VAIO Digital Studio PCV-RX580 PC...
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Remove outer cover
Have you checked the screws on the back? On most cases, if you look at the front of the case, it's the left that comes off, so look for any screws and any latches under the front face.
Jan 13, 2009 | Sony VAIO PCV-RX470DS PC Desktop
Installing standard third-party optical drives in VAIO PCV-650 case
Hi there. I've worked for Sony VAIO and can assure you that the only solution is to get a Sony Branded Spare parts. The parts of Sony VAIO are very specific. As of now I see that the only solution for you is to either contact Sony Service Center or go for an external DVD Drive.
May 16, 2008 | Sony VAIO Digital Studio PCV-RX650 PC...
SONY VAIO PCV V1G
Model:PCV-V1/G
Unplug everthing and place PC face down on bench with base over edge. Earth yourself.
Swing pc unit forward and unscrew the case retaining screw on both sides of the pc unit, swing unit other way and remove other two screws. Case can be loosened, pull large cover up and remove both sides. Parts are then exposed. A shiny metal box covers the memory on the left side of the PC unit. Remove tape that retains it,slide and lift off from the edge facing you.
Ten minutes tops....good luck, much better performance.
Apr 03, 2008 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
