Question about Proform Cycling
Profrom xp 70 bike is very load when you peddle
When you peddle the bike is louder then normal
How do I take off peddles ?
Ondersteun de cranck en sla aan de bovenkant op de crack met een hamer. Het "schrik-effect" maakt de pendalen nu vaak los.
Oct 20, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
How do i install pedals
Right peddle has a right hand thread, normal, and left peddle has a left hand thread. On the left peddle you need to turn it clock wise to loosen it, counter clockwise to tighten
Aug 07, 2014 | Shimano SPD Mountain/Spinning Bike Cleat...
How do you remove / service the bearing on the bottom bracket? I have tried to open the assembly but have been unable to separate the crank. There is a defininte creak when under load and "sometimes"
On a bike???! On a bike to service the bearings
at the crank (peddles) remove chain
rrmove peddles then there will be a lock
nut at base of peddle crank remove it
then slide the whole crank out of the
opposite side an there you go you will
have you bearings in plan view if bearings
are busted replace if they are good
clean an repack with grease an reassemble
Jun 13, 2014 | Merida Mission 3000-D
My son peddle came off i guess his bolt that holds the peddle together got worn out is there a replace part for it....i juss need the screw that holds it together he has a smartcycle bike the 1st 1 they...
Most peddles have to simply be replaced when the bolt is damaged. There is no way to replace the part. They have new peddles for all kinds of bikes at your local bike shop.
Nov 08, 2010 | Cycling
Need to know the gap for the spark plug for a 2003 suzuki rm 125
IF I REMBER CORRECTLY ITS 30 TH INCH I DON;T HAVE THE BIKE OR MANAUEL ANY MORE BUT YOU CAN GET A NEW PLUG THEY COME PRE GAPED AND IT CAN;T HURT PROFROMANCE GET A WIRE PLUG EV
Oct 17, 2010 | 2003 Suzuki RM 125
Ok so i have a loud roaring sound when i get above 50km an hour. It sounds like a normal sound of a car but louder then it should be. and it gets louder at 70 to 80 and then after that it a little softer
it could be a wheel bearing, or tire? but that a guess from a guy on the net that hasnt seen the car. See if you can find out front, rear, right, left.
Aug 31, 2010 | Honda Prelude Cars & Trucks
Left peddel is stripped will not stay on
If it is the peddle that is threaded and not the crank then all you need to do is replace the peddle. Take the peddle off and look at the thread both on the peddle and inside the crank. Any bike shop can look at this for you and can order you in a set of new peddles or, if the crank is to blame you can order these easy enough online.
Jun 09, 2010 | Huffy Brazen 20 Boys' Freestyle BMX...
Washer is louder than normal The drum seems to
the bearing assembly is beginning to fail.
requires an overhaul.
this problem is far too common with Kenmore and frigidaire front loaders
Mar 24, 2009 | Kenmore 43042 Front Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Cycling Logo
Top Proform Cycling Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Tom Chichester
Are you a Proform Cycling Expert? Answer questions, earn points and help others
