Question about Electrical Supplies
The digits on the meter are being difficult to press as aresult am failing to load units
Wont play music
Steven hi! Not checking this baby is difficult but I can give some suggestions in general. 1) Is the machine mechanism moving when play is pressed 2) Is the tape okay test it on another machine 3) Get a known working tape and try it 4) Power if battery operated test the batteries on a battery tester that loads the batteries as digital meter readings is useless 5) Do you hear any soft noise on the speaker when the unit is running 6)How clean are the heads and their condition 7) Turn the volume up and make sure the speaker/s are connected 8)Has it a radio part too and does that part work okay. I do hope this helps and some are obvious but I had degree engineers tripping over the most obvious faults
Oct 19, 2014 | Audio Players & Recorders
The start button is worn and it difficult to turn on
Possible that the controller unit is faulty and timer unit rotor has failed. Use some lubricants - WD 40 - to free the motion , is not you need to replace the timer controller
Apr 10, 2013 | Kenmore HE2 Plus Front Load Washer
I ordered and bought the control panel part for my kenmore elite front load washer but the washer is still not washing it's flashin FH
fh is a water problem,does it fill with water?....... FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1HSpZo0dW
Mar 23, 2011 | Kenmore Elite 45986 Front Load Washer
Bike will crank over but will not start.
It sounds like you are losing power to your coil. This is why it will fire only once and then quit. To verify this, connect a test light to the small connection on your coil that has the white wires runing to it. Turn on the switch, the test light should come on. Now press the start button. If the test light goes off and stays off, this is what is happening. It may come back on after a few seconds. If so, you have a short somewhere causing your igniton circuit breaker to trip or the circuit breaker is bad or you have a bad ignition control unit. The control unit is very difficult to diagnos since Harley uses a particular type of meter to do their testing with.
Using a DVOM (digital volt ohm meter) test the resistance of the primary circuit of the coil. Remove the white wires and pink wires from the small connections. Now, put the meter in "R X 1" scale. Touch one lead lead of the meter to each of the connections. You should read about 3-4 ohms of resistance. Any more or less than this, your coil is bad and you need a new one.
Apr 29, 2010 | 1993 Harley Davidson XLH Sportster 883
The ink system has failed and can not longer print
Note: one line descriptions are difficult to troubleshoot.
Please get back to us with the following information
* What is the exact error message?
* Where exactly you are receiving this error message?
* Does the same issue persists even after replacing the cartridge?
* Any lights are blinking on the unit?
* Does the unit print a self test page? Steps are given below:
  1. Load the input tray with unused plain white paper.
  2. Press and hold the Cancel (c00636162.gif ) button and then press the Start Copy Color (c00636190.gif ) button.
  3. Release both buttons. The self-test page prints.
Please get back to me with the above information for further troubleshooting
:) Dr Tony
Apr 08, 2010 | HP DeskJet F380 All-In-One Printer
Krups XP2070 Stops putting water through after a few seconds and screen flashes and on/off button flashes. Does this when head is removed and descaling too. It will start to flow once switched off/on and...
Most likely a faulty flow meter unit which is not providing the right information to the control unit. Replacing is not too difficult and the replacement meter is < $20.
Nov 01, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
I drive an eighty-eight olds mobile and in the winter it wont start and its not the battery because i bought a new one. can you tell me how to fix it
It still can be the battery as there are minimum requirements for the electrical system. They have a minimum Cold Cranking Amps (CCA) that can be found when you purchase a battery there is a chart for the vehicle make/model/year and minimum CCA requirement. If your battery doesn't have enough it will be difficult or fail to start. Also make sure that the battery undergoes a draw test before you buy a new one to ensure it isn't faulty. They'll attach clamps, like on jumper cables, to the battery that are attached to a box and meter. There is a button they press that draws a load from the battery and the meter will show that the battery can take the draw of starting an engine without a problem. Good luck to you
Oct 16, 2009 | 1999 Oldsmobile Eighty Eight
Exactly the Same Problem
It's difficult to say without seeing the machine or having a failure code.
The machine looks for a switch to close as it fills with water. Maybe a pressure switch?
You could find the switch and see if it clicks when blowing into it and even test it with a meter.
That's an easy test.
Maybe the module has failed.
Hope it's given you something to look for.
regards
john
Aug 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
The coil of cooling system has problem
It is most likely
1/ Your defrost timer or sensor has failed.
or
2/ Your defrost element has failed.
Your timer or sensor is the cheaper to replace so try that first.
May 09, 2009 | Refrigerators
I loaded a new roll of paper and can't get the plotter to print. I rebooted and now have 2 error lights, 1 for data, and 1 for cartridges. What to do?
Take out your paper (check if you are loading the roll from "underneath" and not from the front) . Switch off and on. If the machine gives you the same fault again, press cancel for about 2 seconds, it should then go to ready mode. If it does not then you have a carrage sensor failure. In any case the sensor is failing and its finding it difficult to find the paper. Its a bit technical but if the sensor fails you will need to replace your carrage (head) unit
Dave
Feb 23, 2009 | HP DesignJet 430 InkJet Printer
Electrical Supplies Logo
200 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
