Question about Python Vehicle Parts & Accessories
Error code 1
I have a 2007 Ford Mustang with a Python remote for the alarm system. It was working fine until this morning. The series number on the back appears to be RPN 7341 V P X and each letter has a slash between them. I was going to use it to open the doors this morning, and it did not appear to perform that function. The battery indicator shows fully charged. I removed the battery, and reinstalled it, and the startup tones came up correctly. On the display panel showing the diagram of the vehicle, there appears to be a 1 where the front passenger headlight would be actually located on my car. Also, on the display face near the upper right corner, there is a flashing symbol, but it is indistinct, and flashes too rapidly to see what it is.
mohammed387
  • 1952 Answers
SOURCE: won't start key symbol flashing
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
Posted on Oct 06, 2008
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
SOURCE: problem with ford explorer alarm imobiliser
You should have a switch under the dash and then just turn it to the off position. If you don't or it doesn't work (like mine) then, there is 2 fuses under the dash, put the key in the ignition and turn it forward, pull one of the fuses out and then start the car that should reset it. Then you should be able to put the fuse back. Sometimes if you put the fuse back before starting it the alarm will just continue to try and reset itself, but not start the car. If that doesn't work I have a mechanic who can pull the whole alarm out and when hes done it would look like nothing has ever been installed. Hes very good. I ended having him take my alarm out when I had the same incident happen after the 2nd time.
Posted on Feb 24, 2009
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
I have a used 2014 expl intercepter with python alarm. The remote is not functioning due to water damage. I have key to unlock the doors but the alarm will not silence and vehicle will not start.
unlocking driver door only silences a factory alarm. put the python in valet mode until you can get another remote. key on hold valet button for 5 secs and led should glow all the time.
Jan 15, 2018 | Python Vehicle Parts & Accessories
Mustang alarm
Ford sold a Ford branded alarm through the parts department. These sometimes were a dealer installed option on new cars. Mine would randomly stop responding to the remote and I would have the same symptoms as you describe. I had it removed and the original equipment factory system still worked. Be warned, if you have the Ford "accessory" alarm, your key fobs (remotes) are different and the method to program them is different from what you will read online. You can tell if you have the system by looking at your key fob. The standard Mustang key fob is a 4 button (lock, unlock, panic, and trunk). The accessory alarm uses a 3 button remote and clicking unlock twice would pop the trunk. I really wish I had a picture of the remote because there are 3 button Ford key fobs for cars without a trunk release although I don't think you should have one on a Mustang. Long story short, if you have the accessory alarm, you can solve your problem by having it removed but you will need new 4 button key fobs to remotely lock/unlock your doors
Apr 04, 2014 | 2003 Ford Mustang
Python alarm (460 HP) will not lock doors
The lock button in your remote may be faulty.
Nov 13, 2013 | 460HP Security System
Python car starter
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Oct 16, 2013 | Vehicle Parts & Accessories
Set up the car remote
A 7701P is a remote transmitter. It is not an alarm. You must know the alarm's model because different models have various ways of programming transmitters. In other words, you do not program the 7701P. The frequency is already fixed. You must program your security system to teach it that transmitter's code. Look up the manual for your security system. Instructions will be there. This typically involves turning the ignition on/off a specific number of times and pressing a valet/programming button (or switch) a certain number of times and then pressing a button on the transmitter.
Jan 31, 2013 | 990 And 950 Responder SST Remote - 7701P
Python car security won't let me start my car
It sounds like you might have a dead battery in the car. When the alarm is losing power due to a bad connection or faulty battery it will act exactly as you have described. You can disarm any DEI alarm by turning the ignition on with the key and pressing the valet switch one time.
Hope this helps you out.
Jan 11, 2010 | 460HP Security System
Codealarm keyfob on 2005 Mustang not locking/unlocking doors.
Try this http://m.wikihow.com/Reset-a-Factory-Car-Alarm g
Nov 20, 2009 | Code-Alarm Code Alarm Transponder
Intermittent arm/disarm of Python model 560XV
this "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Jan 15, 2009 | DEI Python 1400XP Remote Start/Keyless...
Vehicle Parts & Accessories Logo
Top Python Vehicle Parts & Accessories Experts
Kevin Daniels
richie46
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
