Wg102 802.1q I have a cisco small buisness switch hooked up to a netgear prosafe wireless wg102. I am very experienced with vlan tagging and networking in general. When I checked the box that says "enable 802.1q vlan" and the router reboots, I am no longer able to access it. Whether I have my switch set as access or trunk or any other setting that I can think of. I think the problem is with the wg102, but I though that when I checked the box the AP would come back up and keep untagging in vlan 1. Has anyone else had trouble with netgears in this senario.
  • ghiel
    ghiel Dec 31, 2013
    Obviously when I say router I mean AP. Old habit.
4 Suggested Answers
alex8642
  • 21 Answers
SOURCE: 4350 Small Network Access Point's web-based configuration tool
If it is trying to connect to the internet when trying to get to the tool, you have to get a direct link to the tool. You might find this on a forum somewhere. It might also help to update your firmware, this may solve your problem immediately. The only problem with routers is that they are built to connect to the internet.If you don't have the internet it is a tedious job to get access to your access points settings. Just get the link to the page and you should be able to change your settings then.
Posted on Feb 24, 2007
  • 62 Answers
SOURCE: CISCO 2800 router interface stop responding
What kind of cable do you have connected from the DLINK to the Router? Is it an ethernet cable 3,5e,6?
Posted on Sep 15, 2007
  • 30 Answers
SOURCE: How can I change the default management vlan (vlan
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Posted on Dec 05, 2009
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
Does a netgear jgs524 support vlans?
The JGS is an unmanaged switch. It has no settings to configure or reset. When it receives a packet, it might preserve its VLAN tag when forwarding it, but there is no way to configure it to notice or handle VLANs in any particular way.
Jan 10, 2013 | NetGear ProSafe JGS524 (DHJGS524NA)
Need to know if NetGear JGS524F switch supports VLAN's.
The switch above is an unmanaged switch so no it wont support VLans, sorry
Mar 02, 2011 | NetGear JGS524F ProSafe 24-Port Gigabit...
Cisco asa 5500 - sh interface - reveals switch ingress policy drops - what are these ? will they slow down traffic ?
The following is an excerpt from cisco.com defining policy drops and their possible causes:
This drop is usually seen when a port is not configured correctly. This drop is incremented when a packet cannot be successfully forwarded within switch ports as a result of the default or user configured switch port settings. The following configurations are the likely reasons for this drop:
blank.gifThe nameif command was not configured on the VLAN interface.
Note blank.gifFor interfaces in the same VLAN, even if the nameif command was not configured, switching within the VLAN is successful, and this counter does not increment.
blank.gifThe VLAN is shut down.
blank.gifAn access port received an 802.1Q-tagged packet.
blank.gifA trunk port received a tag that is not allowed or an untagged packet.
blank.gifThe security appliance is connected to another Cisco device that has Ethernet keepalives. For example, Cisco IOS software uses Ethernet loopback packets to ensure interface health. This packet is not intended to be received by any other device; the health is ensured just by being able to send the packet. These types of packets are dropped at the switch port, and the counter increments.
blank.gifThe VLAN only has one physical interface, but the DEST of the packet does not match the MAC address of the VLAN, and it is not the broadcast address
Throubleshoot these and see if any of them apply to you. Thank you for choosing fixya.com.
Dec 04, 2010 | Cisco (ASA-SSM-AIP-20-K9=) Firewall
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Feb 06, 2008 | Cisco Catalyst 4006 Chassis ( 4006)
DMZ HOST IN FVS 124-G
The Netgear FVS124-G is a superb combo VPN firewall DSL/Cable small business router. Loads of features and Dual Wan to boot. I highly recommend it's use in small businesses But... Keeping the necessary firewall, you are missing another component in a properly segmented network, a VLAN switch. It is highly customizable and gives you the configurability and speed you are asking for. Look at it's features here: ftp://downloads.netgear.com/files/FSxxxT_GSxxxT_smartswitch_UserManual.pdf The normal network security plan is: Internet -->Firewall-->Router (or Firewall/Router)-->VLan Switch-->Individual computers or VLan subnets. Using these two components together makes a more configurable and MUCH easier to setup network than using, say, one Sonicwall, or one CISCO PIX-501-BUN-K9 (which doesn't do VLan and you have to know Pix commands) You get FREE pre-sales and FREE post-sales support from Netgear, so call them on what makes sense for your situation. Sales Support (408) 907-8000 OR Email at: sales@netgear.com ZT3000 "Beta tester of "0"s and "1's"
Aug 03, 2007 | NetGear ProSafe FVS124G (FVS124GNA)...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
