Question about Radio Communications
Commercial radio model
I have a KenwoodTM-271A commercial band radio I can't to transmit on m 150 MGZ frequency, even tho it receives on it. How do I determine the model number of these unit, and it is the wrong model, can I change it to transmit on my frequencies?  Thank you.
    Brigadier General:
  • 6,966 Answers
A Kenwood TM-271A is an amateur radio and therefore restricted to transmit only from 144 - 148 MHz but can receive from 136 to 174.
The TX restriction is done with a resistor (R119) which inhibits transmission outside of the 144-148 band. It is located very near a large IC (IC252).
Depending on your country's radio communications policies and/or your radio license privileges, simply removing R119 would allow transmission outside of the 144-148 MHz.
Hope this be of some help/idea. Post back should yuo need additional information.
Good luck and kind regards.
Posted on Oct 20, 2007
  • Louie  Role
    Louie Role Feb 01, 2008
    Hi again dustyMT,
    Any development with your Kenwood TM-271A?
  • 36 Answers
Simply Put, modifying an AMATEUR radio for use outside of the 144-148mhz band is completely illegal. These radios are not spec'd for operating in the commercial VHF Band, and modifying it to do so may cause not only failure of the radio, but when transmitting you may interfere with other commercial frequencies, ie..fire, police, and if you are caught with the modified radio, may even face a huge fine or Jail time. Put bluntly, your better off to go out and purchase a proper VHF Radio for use in the frequencies which it is intended.
Posted on Jan 02, 2008
Maximum allowed FM TX wattage in South Africa?
I would strongly suggest that you investigate the rules about transmitting in that country. 88-108 in the US is reserved for commercial broadcasting (FM). Are you a US citizen? If so, I would recommend that you get your Amateur Radio license in the US which is usable in most other countries. Then you are legal. (But only in the frequencies for that country.)
Jan 23, 2018 | Walkie Talkies Radio Communications
Can talk on walkie but cannot hear others
It can be several things. The type of radio, Business band, Ham or Consumer would help. This problem can happen easily. Depending on the brand and model the procedures are a bit different. The transmit frequency is correct since radios can "hear" you. Your receive frequency, or the CODE is different that the transmit frequency and code. These are two different things and must match the transmit information in order to turn your speaker on. To check, if you know how to put your radio into "monitor", you will be able to hear the other radios when they transmit. Then you know to only change the "code". The other unlikely thing is a blown speaker. 90% of the time it is the programming.
Jul 04, 2016 | Radio Communications
I cant talk on any frequency over 148.000 anyone know why?!
This is an Amateur (Ham) Radio 2-meter Transceiver. It will only transmit on the 2-meter Amateur band (144-148 MHz) but has expanded receiver coverage from 136-174 MHz which includes Public Service and Commercial 2-Way Radio bands. Please note that an Amateur License is required to operate on the 2-meter Amateur Band.
Dec 26, 2013 | Yaesu Ft 1900r Vhf Mobile 55 W Two Way...
I have a tk-250 I can receive calls but cant transmit when I go to talk and all it does it beeps what do I do
You may have the "tx offset" turned on and may be trying to transmit on a frequency that is considered "out of band" for the radio. Or the frequency you're attempting to transmit on is simply out of band for that radio. It depends on where in the world you're using the radio. If it was a Euro or Japan radio and you're in the US or South America, the bands are different.
Sep 16, 2013 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Can the GRECOM PSR255. be used to scan for aircraft /airband frequencies
Your radio is not capable of recieving air band frequencies. It will only receive 4 bands consisting of: 26 - 54 MHz; 68 - 88 MHz; 137 - 174 MHz and 380 - 512 Mhz.
The VHF airband uses the frequencies between 108 (just above commercial FM radio) and 137 MHZ (just below 2 meter Ham radio). Amplitude Modulation ("AM") is the mode that transmissions are made. The lowest 10 MHz of the band, from 108-117.95 MHz, is split into 200 narrow-band channels of 50 kHz. These are reserved for navigational aids such as VOR beacons, and precision approach systems such as ILS localizers
Jan 26, 2013 | Grecom Gre Psr-255 50 Channel Handheld...
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Feb 29, 2012 | Motorola Radio Communications
I jus was wondering, can the cb radio and the handheld radio transmit on the same channel? Im a security officer and im interested in purchase a cb radio so we can use it at work but i dont know if its...
CB radios and hand-held CB radios can operate on the same channel and be in contact with each other. Other hand-held radios do not operate on the same frequencies and even though they may have channel numbers the channels have different frequencies and will not operate to CB radios.
Oct 29, 2010 | Cobra 150 GTL DX Base CB Radio
How can I tx on 81.575mhz. I have a bespoke external antenna for this frequency
What brand and model radio? Most ham radios cannot transmit on this frequency, as it is far outside the amateur bands. Even modified radios would rarely be capable of transmitting on the frequency referenced.
Dec 02, 2009 | Vertex Radio Communications
Realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Radio Communications Logo
271 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
