Sony lbt-zx99i home system play for a while then the functions are inoperable. Locked on cd fuction. The power switch does not work then.
If left unplugged or off overnight it will play for a while (10 to 90 mins), it varies
    New Friend:
  • 13 Answers
What I did to fix an old stereo or receiver is to open it up carefully and removing then wiping the connectors inside on the main circuit boards all of the connectors slowly and one by one so that you don't forget where they go most are very thin delicate wires so don't snap them!! be careful ,Good luck Sony lbt-zx99i home system play for a while then t - 6_5_2014_5_07_46_am.jpg
Posted on Jun 05, 2014
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: LBT-ZX99I Shelf System i have a Sony lbtzx991 and
The fault is with the front panel IC, a connecctor to the front panel or a crack in the front board. You need to check well and DO NOT ATTEMPT to repair if you are not equipped as a false move can damage the unit.
Posted on Oct 28, 2011
Hi, my Sony LBT-ZX10D HI FI system does not play the MP3 DVD/CD burned from my computer, software used to make MP3 DVD/CD is Nero 10. Any help will be greatly appreciated. Thanks
Make sure that you select the "finalize" option when recording disks on a computer that will be played on home, auto or portable stereo equipment. The finalizing step is not required if it will only be played on a computer.
Jul 14, 2015 | Sony Computers & Internet
IPOD DOCK CONNECTOR DAMAGED
You can look up Andrews Electronics in Valencia, CA. They are a large distributor. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 12, 2013 | Sony Muteki Hi-Fi Music System LBT-ZX99i /...
It will turn on but none of the other buttons will work
From the description this indicates the microprocessor control ic is failing, unplug power from wall receptical, now press and hold power for 2 minutes in an attempt to reset the ic, if no change! cheaper to replace the book shelf system.
Apr 22, 2012 | Sony LBT-D290 Shelf System
LBT-ZX99I Shelf System i have a Sony lbtzx991 and the controls on the system not working besides the volume but all the functions working when i use the remote i would like to know what causing that...
Oct 28, 2011 | Sony LBT-ZX99I Shelf System
I have a Sony lbtzx991 and the controls on the system not working besides the volume but all the functions working when i use the remote i would like to know what causing that problem and how it can be fix...
The fault is with the customer panel and can be due to failure of the subprocessor to the customer cases. The main processor and the basic sections have no issues and this can be sometimes due to even a fault connector to the front panel. If you are able to remove the front panel and take a good observation using a magnifier, it might be useful, try to test the panel IC, check the connectors, solder if you suspect any dy joints and it must solve the case. Attempt only if you are equipped as the set works well and must not be tampered to a bad state.
Oct 24, 2011 | Sony LBT-ZX99I Shelf System
MY SONY LBT-LX90AV CASSETT PLAYS DISCORD AND BELT FALLS OFF
Hi. Make sure the flywheel turns freely and that the capstan pin and pressure roller are clean. If this is OK then it is more than likely that the belt is stretched, dried out or generally worn. These parts only have a certain usable life and are quite cheap to replace.
Dec 23, 2008 | Sony LBT-LX90AV CD Shelf System
FUCTION BOTTON
replace a new one tact switch! (function button) your tact switch is not working!
Sep 23, 2007 | Audio Players & Recorders
55 people viewed this question
 Grubhead
Grubhead
