All of a sudden, I open the freezer and find frost all over everything in the freezer. It wasn't that way this morning, now, 10 hours later, it's all frosty inside. What's happened?
My refrigerator has started to frost in the freezer freezer compartment and frost over the air...
(More)
My refrigerator has started to frost in the freezer freezer compartment and frost over the air vents. As a result, it is not keeping the temperature in a safe range. What needs to be done?
There are two water lines coming out of the back of the fridge. One of them appears to be an over...
(More)
There are two water lines coming out of the back of the fridge. One of them appears to be an over flow. There is another over flow line coming out of the door. The problem is that there is no water going to the ice maker or the door water dispenser. And, what I think is the over flow line pumps water into the drain pan when you try to get water out of the door. Is what I think is an over flow actually an over flow, or is it disconnected from something? It has no fitting on it, and I can't find an open fitting on the fridge.
We recently moved into a new condo. The freezer side seemed to be working fine, In the last day or...
(More)
We recently moved into a new condo. The freezer side seemed to be working fine, In the last day or two , it has dropped to -20F. The I noticed the fridge side is up to 45. I tried to do the adjustments according to the owners manual, but it cannot get it to stay where it set it.
