Question about Pyle PLTS78DUB Car Video Player
Installation Trying to install in to a 2008 Ford Mustang GT. Unit came with a conversion cable but the converted end doesn't match any plug block on the Mustang. Do I need a different conversion cable? Where do I get one?
    Problem Solver:
  • 12 Answers
Crutchfield has a good selection of wiring harnesses complete with kits and instructions. Crutchfield.com
Posted on Dec 31, 2013
4.6 Engine valve train in 2008 Ford Mustang Gt
    mages for 4.6 Engine valve train in 2008 Ford Mustang Gt
    More images for 4.6 Engine valve train in 2008 Ford Mustang Gt
    2005-2009 Mustang Cylinder Heads & Valvetrain ...
    www.americanmuscle.com/mustang-valvetrain-0508.html
    They help your motor breathe better and also make sure your Mustang gives top-notch throttle response. ... 2005, 2006, 2007, 2008, 2009 Mustangs; V6, GT, Bullitt, Shelby GT500, ... 2005-2009 Mustang GT Cylinder Heads & Valvetrain Components ... (6).Ford Racing SOHC 3V 4.6L Head Changing Kit (05-10 GT) $76.00.
    Mustang Camshaft Facts & Technical Information ...
    www.americanmuscle.com/camshaft-tech-guide.html
Feb 08, 2016 | Ford Cars & Trucks
Got few problems arising in my Mustang GT 2008: 1)
1. Brake booster diaphragm may be torn.
2. Tie rod ends may be failing.
3. Likely lifter noise. Change to better oil and oil filter.
4. Hood stops need adjusting.
You need a mechanic.
Sep 17, 2017 | 2008 Ford Mustang GT
I have a 2008 gt mustang why would it misfire on number 8 cylinder
Hi there:
May mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
Possible Solutions: If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 09, 2012 | 2008 Ford Mustang GT
1992 ford probe gt 2.2l turbo no spark have changed plugs wires cap rotor coil distributer
1989 ford probe turbo 2.2L turbo the oil filter sandwich block thats adapted to the block of the motor... the Hole that comes out block and from where the sandwich adapter mounts to the block... is there suppose be some sorta plug or fitting there? is there possible get detailed picture so i know what im missing?
i have hole and ******** oil out... and trying get fixed so i can sell the car... to fix my current problem no motor for a mustang 5.0 gt so if anyone can help me out id greatly apppericate it...
Mar 07, 2011 | 1992 Ford Probe
I need to know how to install a serpentine belt on a 4.6 ford roush mustang (2006) with a supercharger
put a socket wrench on the tensioner pulley and act like you are tightening it when you do that it will take tension off of the belt and then take it off and put the new one on in the same direction and repeat the process on the tensioner and you will be able to install it no issues
Jan 09, 2010 | 2007 Ford Mustang GT California Special...
I have a 2008 mustang gt with a Whipple HO supercharger, under boost the car is breaking up. the car has MSD coil pack, brisk spark plugs gapped at .030.
it could be something with mass airflow sensor make sure whomever installed the supercharger replaced or reflashed that appropriately
Aug 14, 2009 | 2008 Ford Mustang
2005 MUSTANG COVERTIBLE MY REAR WIDSHIELD GLASS IS FALLING OFF
This problem is very common and is known as delamination.
If the problem is not too far advanced, you can repair it with Urethane adhesive. It is used by glass shops to install windshields.
Your top and window unit are two separate parts.
If the problem is beyond repair, you will need to remove the rear half of the top and replace the window unit.
Karl at topgunwon.com
Feb 25, 2009 | 2007 Ford Mustang GT California Special...
Pyle PLTS78DUB Car Video Player Logo
148 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
