Question about Crosley CR78CD-P CD Shelf System
CD will not stay in place to play - drawer keeps opening
CD drawer keeps opening - won't stay shut to play
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Draw will not close
Look under the drawer and look for a plastic pin sticking up. This pin needs to be in the track on the bottom of the drawer for it to close and load correctly.
Feb 22, 2013 | Panasonic DVD-XV10 DVD Player
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
Cd draw opens on power up and won't play a cd keeps opening after closing
This unit needs replaced it has seen better days sorry. The only thing you can try is shut off all power to the PC then unplug the PC and that cd drive from the rear of it. let the PC boot all the way up so you see your desk top. Shut it all the way down un plug PC hook back up the wires on the back of the CD player let it boot back up see if this stops it.Remember to rate my solution this is how i earn my achievements also testimonial Thanks much in advance.
Apr 22, 2012 | Dell Dimension 3000® Pentium® 4...
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Crosley CR78CD-P CD Shelf System Logo
43 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
