Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My light on my craftsman garage door opener won't turn on
I changed the light bulbs. I tried the wall mounted on off button for the light does anyone have any other ideas why it doesn't work.
    President:
  • 3,197 Answers
Unplug the unit from the power and take a small screwdriver and lift the center contact in the light sockets just a bit. This usually fixes the problem if you haven't had electrical surges or lightning.
Posted on May 20, 2009
I just installed my garage door opener, but the light won't turn on and i can't align the sensors, i get to the point where the green light stays steady for a few seconds then it blinks then it goes to steady and blinks. any idea what i did wrong?
Posted on Mar 29, 2010
  • 10,865 Answers
If your door does not go up and down check the circuit breaker or fuse box.
Doorguy27
  • 30 Answers
SOURCE: 1.3HP CRAFTSMAN CHAMPION GARAGE DOOR OPENER-NEW IN 2004
Well sounds like its a pressure setting. you said you open the door by hand? Was it easy to do? Ask your self this can a 15 year old kid open it and close it? If so then it sounds like its a presure setting There should be two blue slots on your opener with numbers 1-9 says up and down force. Turn the up force towards the bigger number. Just a little bit. But before you do that as the other guy stated make sure that your cables and springs are working. Spring depending on your doors can be in three places but we going to assume you has the most common set up so look over the top of your door (with it closed) you should eb able to see a tube running across there. and somewhere in the in middle a set of spring look at the spring to make sure that you dont see any of the tube showing in the springs. Becare not to touch the spring as they are under a lot of stress.
Posted on Feb 10, 2009
moeshere
  • 33 Answers
SOURCE: craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Posted on May 17, 2009
  • 3197 Answers
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
Remote won't work but keyless entry does on garage door
If the light in the wall control is flashing press and hold the lock button for 3 seconds. Your remote should now work.
Jul 23, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote works only when Garage Door Opener light is OFF
I discovered that certain light bulbs interfere with the remote sensors. Harware stores have clear vibration reisistant bulbs for garage doors, try them instead. After spending money on a new remote, resetting remotes, and weeks of aggravation...poof.....i found it was the type of bulb I was using. Used a clear bulb and the problem went away. Hope this helps.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on its own
u have to erase all memories in the receiver.. push the learn button for like 10 sec.... and memorize again ur transmitter by presing the learn button once and the the transmitter button... try it again..
Mar 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
4,988 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
