Question about Fisher Washing Machines
Water drains but won't spin
Smart drive 5.5 phase 5 water drains ok but spin won't start, drum gives slight kick doesn't spin
    Sergeant:
  • 187 Answers
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
Posted on May 22, 2009
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
My washer won't spin on spin cycle
Hi rapwizz,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Whirlpool Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
GW709 MACHINE SMART DRIVE LOAD 7.5
hi
if it washes ok but won,t spin it canbe pump if it has not pumped all the waterout or can be lid switch,but normally they won,t wash if the lid switch is funny so i would be checking the pump side of things
cheers grantsreps
Aug 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel no spin, no rinse
hums sound proble coming from the drain pump. sounds like its trying to pump out water but cant. try tipping back andsee if you can spin the pump manually, (usuallya fan cooling blade coming outta back end of pump.wont spin if it cant drain
Mar 22, 2008 | Washing Machines
Washing Machines Logo
219 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
